Old 06-12-2006, 07:52 PM   #1
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
whats the final word on SUBFRAME BUSHINGS? NOT INSERTS
What is the final word on RUBBER/POLY subframe bushings? I mean the ACTUAL REPLACEMENT ones, not the inserts.
So far, the only thing i've heard of is using the 300zx subframe bushings from Energy. HOWEVER, those are a LOT taller. I would think this would adversly affect handling... Has anyone tried trimming these down? Know of a better solution?
Just for history, i have the poly/glass INSERTS. They helped a lot, but i want a more solid feel. I dont want to go with full metal bushings though. The full metal bushings ride way too hard for my personal preference. The work involved doesn't scare me, but i only want to do it once, and right.
ALSO, has anyone replaced the differential bushings? did that do anything at all?
thanks a bunch guys.
gotta240 is offline   Reply With Quote
Old 06-12-2006, 08:44 PM   #2
Dousan_PG
Dousan_PG's Avatar
iirc
chris fosberg did this on the s15 (solid metal bushings)
broke axles
upgraded axles
broke his ring gear.
and he's barley pushing 400 rwhp
diff bushings? no need. i use s13 diff on my s14
and the rear is 2 bolt, no biggie.
Aaron
Pink GodziRa
Old 06-12-2006, 08:52 PM   #3
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
im running the z32 energy bushings and theyre great.
aNskY is offline   Reply With Quote
Old 06-12-2006, 09:35 PM   #4
gotta240
Didn't you have to modify something to make them work? Aren't they a lot taller than the stock ones?
Does anyone know how having taller bushings will affect handling?
thanks again guys.
Old 06-13-2006, 04:25 PM   #5
Frenzy13
Frenzy13 is an unknown quantity at this point
Send a message via AIM to Frenzy13 Send a message via Yahoo to Frenzy13
I am going to go with the Silk Road subframe bushings. They are 150 buck.
1992 240SX SE - Goodbye...
1997 240SX - At last I have one...
Frenzy13 is offline   Reply With Quote
Old 06-13-2006, 07:07 PM   #6
gotta240
arent those all metal though?
Old 06-14-2006, 10:34 AM   #7
Frenzy13
I never really thought about it... I saw the blue bushings and they looked poly or rubber to me. I sent an email to drift factory asking them, so i'll post up their response ASAP.
Old 06-14-2006, 11:07 AM   #8
allmotorKA
allmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really nice
Nismo also has subframe bushings which are supposed to be more rigid than stock bushings but softer than the polyurethane ones from ES.
allmotorKA is offline   Reply With Quote
Old 06-14-2006, 11:24 AM   #9
Broaner
Broaner is an unknown quantity at this point
I've got aluminum and I've loved every mile on them so far. But by no means is this a daily.
VQ Powered S13 Coupe
Homepage
Video of the first VQ powered S13.
Since people keep asking I guess I should say I do sidework. Regular stuff to motor swaps if you desire. PM me.
Broaner is offline   Reply With Quote
Old 06-14-2006, 11:32 AM   #10
Frenzy13
The cost of the nismo ones are prohibitive in them selves. While Nismo lists the at like $175, they only come with 4, and according to Nissan you need two set. So it's like 350 for Nismo. As to Silk Roads I have no idea what they are anymore. Modern Speed Labs said that they were replacement bushings. The discription had me thinking poly. Drift Factory said that they aren't replacements, and that they are poly. DF said that Silk Road switches back and forth, but right now they are poly. Ummm... so now I'm not even sure anymore.
Old 06-14-2006, 12:25 PM   #11
R34SKYLINE
R34SKYLINE is an unknown quantity at this point
I previously was using CUSCO subframe collars only but since I did my ES master kit install I also used teh ES subframe inserts with my CUSCO collars and it feels 5x better than before I just cut the slits out and inserted them in the empty spaces in the stock subfraem bushings feels great.
R34SKYLINE is offline   Reply With Quote
Old 06-14-2006, 03:54 PM   #12
aNskY
thanks again guys.
well i couldnt measure them because i burned out the oem bushings, but i didnt have to modifly anything at all. they cant be too much taller because the studs still had plenty of threads available. bolted right up and improved ride quality and handling ten-fold.
i had origionally bought the solid bushings from SPL but i sold them and got the ES because my car is a semi daily driver and i thought the alum bushings would have been too rigid
also, i bought the differential carrier bushings at the same time, because i thought.. its gonna be out.. might as well get them in case they look shot. but mine looked fine.. so back in the box they went.
Old 06-14-2006, 08:52 PM   #13
gotta240
Energy bushings it is then..
did you TRY inserts first askny? I'm wondering how much of a difference between bad bushings WITH inserts vs new energy susp. bushings there will be.
Old 06-15-2006, 04:48 AM   #14
aNskY
no, my bushings were toast.
i didnt think the inserts would have even helped all that much
Old 06-15-2006, 05:40 AM   #15
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
the inserts dont work when the bushings are busted. i've proved this. i actually think the intserts broke my oem bushings
driftingisgay.com
nrg is offline   Reply With Quote
Old 06-15-2006, 06:35 AM   #16
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
Sorry to thread jack, this made more since then starting a new thread, so why is it not a daily driver? are the solids that rough? and how long did it take to install them?
NIK90s13 is offline   Reply With Quote
Old 06-15-2006, 07:30 AM   #17
Broaner
There is no rubber or poly left anywhere in my rear suspension so its tough for me to tell which parts attributed most to the stiff ride. For me the roughness isn't a negative thing at all. The car feels super solid. I like to describe it as vaultish. Nothing jiggles or rattles over railroads or any other road disturbances WI roads can throw at me.
Its not a daily because I want it that way. Its a track only/sunday cruiser when your in a crazy illegal fast mood.
It took several hours all told to install.
Homepage
Old 06-15-2006, 10:39 AM   #18
NIK90s13
NIK90s13's Avatar
^^ cool thanks, that is what I needed, I should be putting mine in this weekend, maybe.
