Old 06-12-2006, 10:13 PM   #1
Mr. Spool
Mr. Spool is an unknown quantity at this point
No Spark and no Fuel
Alright, I have run all the fuel tests (I think) so I checked my spark and neither my spark nor my fuel work after my engine and 5 speed swap in my vert. I am guessing that I did not hook something up right, does anybody know what would cause no fuel or spark. Thanks.
96' SE Turbo'd
Super 60, S-AFC, SMIC, 370cc Injectors,
Open Air BOV, Warblo 255 pump, Stage 3 Clutch
Kyb agx, Sportline Springs
Full body kit, Bomex rear, Drift sides, r34 front
gunmetal rims, yok tires
Mr. Spool is offline   Reply With Quote
Old 06-13-2006, 07:01 PM   #2
Mr. Spool
bump, Come on I could totally use some help. I have now swapped ecu's and am about to start jumpering wires. Does any body know if I need to swap the tps sensors. thanks.
96' SE Turbo'd
Old 06-14-2006, 07:08 AM   #3
street_white180sx
street_white180sx's Avatar
street_white180sx is an unknown quantity at this point
no spark no fuel leads to crank sensor problem if ur not gettin injector pulse nor ignition that usually is the problem. check the signal, check the reluctor wheel on the senor and check the wiring to see if anything got damaged while u were workin on the car. let me know if this helps
1993 S14 Silvia Slant Top, Blitz Bov, Fmic, Catback exhaust, HKS evc 3
street_white180sx is offline   Reply With Quote
Old 06-14-2006, 08:00 AM   #4
S13Eye
S13Eye's Avatar
S13Eye will become famous soon enoughS13Eye will become famous soon enoughS13Eye will become famous soon enough
Send a message via AIM to S13Eye
What engine swap? SR into vert? Make sure all your grounds are connected, and that the engine is very well grounded. KAs and SRs can go completely mental if they don't have a good ground. Check that the ECU connector is nice and snug in the ECU. Who spliced your harness? Get back to us with some more info before we can start diagnosing.
S13Eye is offline   Reply With Quote
Old 06-14-2006, 11:36 AM   #5
the head
the head's Avatar
Check your battery connections as well remember there are three wires that need to run to positive
