Old 06-13-2006, 08:18 PM   #1
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
S14 SR turbo setup questions
hey everyone, i have an s14 notchback sr in my 95 240 and im trying to hit 300 whp, so i was wondering if anyone had any suggestions? my current setup includes-
-walbro 255 lph fuel pump
-blitz fmic
-MR turbo outlet
-MR downpipe
-Apex'i N1 dual exhaust
-Apex'i PowerFC
-Tomei expreme exhaust manifold
-metal turbo suction pipe
As i was saying, i would like to reach 300 whp. Since my hot pipe has oil leaking into it, im assuming my stock GT28 is on its way out, especially since i only achieve .5 bar of boost, whereas for the last year i was seeing .8ish. I was considering which turbo to swip in as a replacement, within a reasonable price... including the S15 GT28, Garrett 2871r, among other turbos. i use my car predominantly on the street, and dont like to go past 6500 rpm too often. the parts i know i will need.. Injectors, but what size is recommended? 300zx mafs, boost controller, but should i go with manual or electronic, and obviously a new turbo. Any insight?
-Bart
DJ_Sunrise is offline   Reply With Quote
Old 06-13-2006, 08:35 PM   #2
Dousan_PG
Dousan_PG's Avatar
u def need mafs, boost controller and injectors
i ran 1 bar w/ pretty much the same setup minus the PFC and i did like 250 rwhp with a safc
but i think my motor was weak.
Aaron
Pink GodziRa
Old 06-13-2006, 10:52 PM   #3
DJ_Sunrise
the two other turbos i have been considering is the power enterprise 1420SP, and the apexi ax series. both are at a decent price.. but does anyone have any information on these, or experience with any of the turbos i listed?
-Bart
Old 06-14-2006, 02:21 AM   #4
HyperTek
one of the guys from C-tune told me they had made 375ish hp out of an sr that had a gt28rs with stock fuel injectors.
Keep it Classy
Old 06-14-2006, 02:40 AM   #5
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
Well they were on crack.
Anyways. I would rec. a t3/60-2 with a ext waste gate, apexi stock bore head gasket, cust manifold with a v band down pipe. 740cc injectors, z32 maf, Hks step 2 cams, rocker arms stoppers, arp head studs, valve springs, and better spark plugs.
Then you can say hello to 370 whp.
blu808 is offline   Reply With Quote
Old 06-14-2006, 12:24 PM   #6
steve shadows
steve shadows's Avatar
HEY! WHAT THE FK is a 60-2?
haha
did you mean a 60-1? or a 62-1? Just curious.
gt28rs? With supporting modes is supposed to be able to make max 350whp.
I have seen dynos close tot hat power level.
btw c-tune used to CARTUNES HAHAHAHA, sorry had to remind everyone.
I know some perps who work their.
Anyways I would suggest a 2871 and be down with it.
Like Me on FaceBook !
Old 06-14-2006, 04:36 PM   #7
blu808
blu808's Avatar
Yes a gt28rs can make that power on the dyno. But if you push that on a track day you will be sending hor beaten air into your ic and eventually heat soak it. Also the gt28rs i dont doubt can make those numbers on the dyno, but not with stock injectors/ maf.
