Old 12-12-2005, 10:37 PM   #1
Slidin240Wayz
Slidin240Wayz's Avatar
R32 GTR and Z32 30mm Caliper Comparison and Question at the end.
Hello everyone,
I just got the R32 GTR calipers in. I have the Z32 Aluminums off the car as well so I can make the comparison. So here goes... Todo es especial (Everything is special).
Red = Z32 30mm Aluminum
Sliver = R32 30mm Aluminum
Top view
The opening is the same on both; 66mm
Piston View
It started at 15mm; app. 36mm on both as well
I didn't take the pic of the Z32 piston, but it measured the same.
Opening for the rotor
Same on both; App. 36mm
Height from bottom to top (not exact inches since the ruler's edge does not start with the first inch). Here is where the difference comes into play.
Z32 at 3 and 15/16 inches
R32 GTR at 4 and 2/16 inches
A difference of 4.76 millimeters. As you can see the measurement is not exact, but I will go by this figure. Since it is just the radius, the 4.76 millimeters difference would allow a rotor that is 9.52mm taller. Once I get one of those cool digital rulers I will get the exact figures.
Weight
They both weight pretty much the the same on my old scale; between 4 and 5 pounds.
I hated the silver that I tried to paint the calipers with, so I went out and bought something a little nicer and this is what I came out with.
So here is the question part.
I have these calipers that can take a bigger rotor. My issue is now, where can I get the rotor for these brakes? After reviewing the ultimate rotor thread I saw that the closest rotors are the ones for the early model Mitsubishi VR4. The later model ones might fit in there as well. Has anyone else done this before? Will I have to worry about the rotor not fitting in the rotor spacing of the caliper? I know I can go with the Z32 rotors, but I want to use these calipers to there fullest potential.
Wishing you all the best,
Carlos Doria
Old 12-12-2005, 11:02 PM   #2
mrmephistopheles
mrmephistopheles's Avatar
R32 GTR rotors, optimally.
They're not impossible to get, obviously.
Originally Posted by PHLIP
Old 12-12-2005, 11:04 PM   #3
CHARLIE2020
CHARLIE2020 is an unknown quantity at this point
Send a message via AIM to CHARLIE2020 Send a message via Yahoo to CHARLIE2020
I miss read, my bad
CHARLIE2020 is offline   Reply With Quote
Old 12-12-2005, 11:13 PM   #4
Slidin240Wayz
Mr. M Can you get a pair for me?
Old 12-12-2005, 11:33 PM   #5
andrewmp6
andrewmp6 can only hope to improve
well you can get the 350z rotors and adaters from splsparts.com or raretrick.com has r32 rotors
andrewmp6 is offline   Reply With Quote
Old 12-12-2005, 11:47 PM   #6
Slidin240Wayz
haha, talk about economical...
Old 12-13-2005, 01:42 AM   #7
mrmephistopheles
it'd be cheaper for you to source them in the states.
Old 12-13-2005, 02:15 AM   #8
kouki_s14
kouki_s14's Avatar
kouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfection
Send a message via AIM to kouki_s14
anyone know how the R33 GTS-T calipers compares to these two?
kouki_s14 is offline   Reply With Quote
Old 12-13-2005, 06:08 AM   #9
Slidin240Wayz
I think the r32gtr and the r33 gts-t calipers are the same. The problem with the track series and the brackets is that the rotors will cut into the brake pad and leave about a 1-2mm lip on the edge, so the bracket is not using the brake pad to its fullest potential. Also it would push my caliper out even further. So the brackets need more work done to them.
Wishing you the best,
Carlos Doria
ps Mr. M how much are they where you are?
Old 02-06-2006, 08:49 AM   #10
MadScientist
MadScientist's Avatar
MadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really nice
OK I actually got the Calipers and Rotors in Today... the hardware is comming on Friday.
Here are the Specs for the GTR R32 (Sumitumo) Caliper
Top Opening:
Across @ opening END - 69mm
Across @ opening CENTER - 73mm
Across @ Length - 120mm
Piston Dia.:
Approxiatly - 37mm (no micrometer)
19mm seperation between Pistons
Bottom Opening
Rotor Gap on Botom - 37mm
I also Noticed the Skyline models have added cooling channels on the inner Rotor Opening!
Height - 4 1/2 Inches
Some noticeable differences especially in Height and Piston Seperation.
Peace
Drew
Follow on IG - KoukiTheToolBox
MadScientist is offline   Reply With Quote
Old 06-20-2006, 08:56 PM   #11
PITCH
PITCH's Avatar
PITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to behold
Will these R33/R32 GTR clear stock SE wheels?
PITCH is offline   Reply With Quote
Old 06-21-2006, 06:26 AM   #12
Slidin240Wayz
Yes they will.
Old 06-22-2006, 07:46 PM   #13
alkemyst
alkemyst's Avatar
alkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nice
Send a message via AIM to alkemyst
There is a difference between Z32/R32/R32 GTS-T and R32GTR. 30mm x 280mm (same as Z32) vs 32mm x 296mm for the early R32's and 30mm x 324mm for the later ones (after 8/93 w/ Brembos)...these are the same for the R33 GTR and R34 GTR Brembos. The rears on these (the Brembos) are 20mm x 300mm vs the 16mm x 297mm on almost all other models Z32, R32, R33, R34 without Brembos.
The R33 GTS-T is right in the middle of the two at 30mm x 296mm
The R34 GT and R33 GTS-T are the same size, but the R34 GTT moves up to a 28mm x 310mm rotor in front, 8/98+
The EVO Brembos in comparison are 32mm x 320mm Front and 22mm x 300mm Rear.
I am running R33 GTS-T's....more than enough brake and much less than GTR's. Also if you are hunting ebay many of the GTR's are really not. Mine were supposed to be based on the auction ad.
Everything but the Brembos pretty much use identical brake parts and hardware as a Z32. Makes finding pads simple.
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master.
alkemyst is offline   Reply With Quote
Old 06-22-2006, 08:20 PM   #14
chmercer
chmercer's Avatar
kindof OT but not really
does anyone know of any 2 piece rotors that will fit with any of the z32-esque calipers
chmercer is offline   Reply With Quote
Old 06-22-2006, 08:45 PM   #15
alkemyst
alkemyst's Avatar
Check out www.dba.com.au, they have a lot of different rotors. Not sure if they have a two-piece though for Z32.
Do you have a particular need?
