Old 07-06-2006, 12:49 PM   #1
DJ8684
DJ8684 is an unknown quantity at this point
Gauge Cluster Wont Light Up! :-( Please Help...
Well i bought a '93 hatch not too long ago and im working out all the little bugs and problems every used car has. Right now im trying to work out my gauge cluster problem. Whenever i turn my headlights, the gauge cluster wont light up. Everything else on the cluster works like the needles work, the milage recorder, the red lights such as brake, seat belt, etc..., the clock works, just not the back lights. When u turn the lights on, u can see the clock dim when u turn the switch like it normally would do. So i thought maybe the little lights may all be burned out... so i pulled the cluster out and changed all of the little lights that would light up behind the cluster and still nothing. So then i figured maybe the fuses.... so i check them, found a couple blown ones and changed em but still nothing..... i wouldnt have thought the wiring would be an issue considering everything else on the cluster workss..... any ideas?
DJ8684 is offline   Reply With Quote
Old 07-06-2006, 01:16 PM   #2
driftkid316
driftkid316 is making a name for him/her selfdriftkid316 is making a name for him/her self
Send a message via AIM to driftkid316
check the fuses under the the dash buy the pedals. its probably bad or maybe not even there. that was my problem.
driftkid316 is offline   Reply With Quote
Old 07-06-2006, 01:17 PM   #3
chlatboy
chlatboy will become famous soon enoughchlatboy will become famous soon enoughchlatboy will become famous soon enoughchlatboy will become famous soon enough
haha. Dude i had hte same problem that you did not too long ago. The problem is the fuse is blowing. On my car its called the meter fuse. I had put in a couple of them, each one of them blowing.
Check to see if your taillights work. There may be a short there causing the METER FUSE to pop. Oh by the way meter fuse in on the drivers side kick panel. I didnt see anythign wrong with the tailghts so i checked the front. Found that i had shredded the corner light bumper lights and the two were touching. This basically shorted the fuse. All i did was to cut the wire, makling sure they did not touch and everything went back to normal. Let me konw if this helps.
If you dont know
SEARCH!!!
chlatboy is offline   Reply With Quote
Old 07-06-2006, 01:51 PM   #4
g6civcx
g6civcx's Avatar
#1 in sig. EL section.
Old 07-06-2006, 02:41 PM   #5
kandyflip445
kandyflip445's Avatar
If you want to get down to trouble shooting then find the main power wire in the cluster and use a multimeter to check if you have power to the circuit that has the lights in it if you do look after were you checked power if you dont' have power look before that point in the circuit. Most likely you have a fuse blown. If that isn't it then you may have a wire somewhere in the circuit that is cut/shorted or otherwise not working as intended.
Good luck.
My 240 vBgarage
Old 07-06-2006, 03:25 PM   #6
DJ8684
thanx for the tips... im gonna check them out to see if i have overlooked the fuses then troubleshoot the wiring next
Old 07-07-2006, 12:56 AM   #7
SANdisk
SANdisk's Avatar
SANdisk is an unknown quantity at this point
im having the same problem with my 90 coupe, the speedo and the odo dont work to, but it also has hud so i think the capacitor is bad because if my car is in sunlight for a long time the hud and speedo will work but othertimes not, i checked all the fuses, but ill double check today.
SANdisk is offline   Reply With Quote
Old 07-07-2006, 05:45 AM   #8
g6civcx
g6civcx's Avatar
Suspect a defective speedo/odo combo. They usually go bad around 150k miles on S13s.
Old 07-07-2006, 10:57 AM   #9
DJ8684
found out what it was and fixed it.... check out this article... i noticed that the previous owner did a hack job of installing and removing an aftermarket radio and found this to be my problem... all better now! thanx guys! :-) http://forums.nicoclub.com/zerothread/158162
Old 07-07-2006, 11:35 AM   #10
kandyflip445
Good stuff! Glad you found out what it was!
My 240 vBgarage
Old 07-07-2006, 08:13 PM   #11
SANdisk
SANdisk's Avatar
mine only has 133,000
