Old 07-30-2006, 10:13 PM   #1
sil80dreamer
sil80dreamer's Avatar
sil80dreamer is just really nicesil80dreamer is just really nicesil80dreamer is just really nicesil80dreamer is just really nicesil80dreamer is just really nicesil80dreamer is just really nicesil80dreamer is just really nicesil80dreamer is just really nice
What turbo do you run on your sr20det?
I want a turbo capable of 300-400 whp. Just wondering what you guys have, and what trim and turbine A/R you have.
sil80dreamer is offline   Reply With Quote
Old 07-30-2006, 11:27 PM   #2
apexiSR202nr
apexiSR202nr is an unknown quantity at this point
GT2871R .64... fullboost around 3800 and can produce mid 300hp easy. do a search with that and tons more info will pop up.
apexiSR202nr is offline   Reply With Quote
Old 07-30-2006, 11:31 PM   #3
trybal
trybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymore
Send a message via AIM to trybal
300-400 is a huge gap to and alot of variations. If your gonna be shooting for 400 hp, you better damn well know what turbos will support it lol. Along with supporting mods. But yeah, if you want power go for a 2871, Once you drive a car with one of those you won't want anything faster
trybal is offline   Reply With Quote
Old 07-30-2006, 11:44 PM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Fuck it go top mount and dont go with anything with a T-2 flange and you should hit numbers closer if not over 400hp. I got a GT2871R .64 trim. Put down 306whp at 1.2 and i want more...
CLICK HERE!!!
Old 07-31-2006, 12:00 AM   #5
carkid0007
carkid0007 can only hope to improve
Flip if upgrading to the gt2871r what all will have to be changed, I have a redtop ?, I know the upgrades like injectors, mafs, ecu...but what about the manifold and anything else ?
carkid0007 is offline   Reply With Quote
Old 07-31-2006, 12:12 AM   #6
trybal
you can use the stock man, just need to modify the intake pipe and new turbo lines
Old 07-31-2006, 12:14 AM   #7
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
gt2871r uses a T2 (OEM) housing. so the stock manifold would work fine. this turbo even bolts up to the oem elbow. they even have a version that bolts up to an sr20 100% now.
driftingisgay.com
nrg is offline   Reply With Quote
Old 07-31-2006, 12:17 AM   #8
carkid0007
Is that the Gt28RS ?
Old 07-31-2006, 12:18 AM   #9
carkid0007
I think my turbo is going bad and Im not putting another t25 in, I'll upgrade.
Old 07-31-2006, 12:55 AM   #10
fliprayzin240sx
Stock manifold, elbow and even the stock T-25 lines will work for the GT2871 Youll need to fab a new intake tract, play with the turbos alignment a bit and make a 90 degree elbow to line up with your hot pipe.
CLICK HERE!!!
Old 07-31-2006, 12:57 AM   #11
McRussellPants
"GT28RS/Disco Potato / zOMG SPORT COMPACT CAR" is the GT2860RS.
The 2871 is the next step up.
Some guy on FA is claiming low 400hp SAE on a fully modded SR with a 2860.
I'll prolly be going 2860. and shooting for 350whp with cams and such.
FA would prolly be a better place to get this sort of Info, those guys just spam the refresh button waiting for the next turbo sizing thread.
McRussellPants is offline   Reply With Quote
Old 07-31-2006, 01:09 AM   #12
sileight_04
sileight_04 is an unknown quantity at this point
Send a message via AIM to sileight_04 Send a message via Yahoo to sileight_04
im runnin a GT35R .63 a/r outlet, .70 a/r intake. it is matted to a peak boost topmount. it is very conservatively rated at 650hp.
sileight_04 is offline   Reply With Quote
Old 07-31-2006, 02:37 AM   #13
Nizzan4u2nv
Nizzan4u2nv's Avatar
Nizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura about
Send a message via AIM to Nizzan4u2nv
Uhm ok. He said 300-400. He can get a t2 flanged gt turbo and keep his same exhaust setup while making his target power.
Nizzan4u2nv is offline   Reply With Quote
Old 07-31-2006, 05:40 AM   #14
g6civcx
g6civcx's Avatar
I'm running the stock S13 T25, Megan turbo outlet, Megan downpipe, Magnaflow 3" cat, and RS*R ExMag for track or stock catback for street.
I will be upgrading to an S15 T28BB when the T25 dies. The reason I don't want anything bigger is due to lag. Even the stock T25 still has a little bit of low end lag, which makes it a little harder to exercise precise throttle control.
Old 07-31-2006, 11:35 AM   #15
carkid0007
How is the price difference for the GT2860, and the GT2871 ?, I read that article you were talking about McRussel also.
Old 07-31-2006, 02:00 PM   #16
trybal
probably the same, if not give or take 200 bucks.. expect to pay 1100-1200 for a 2871
Old 07-31-2006, 03:34 PM   #17
slider2828
slider2828's Avatar
I have a .86 2871R at 16 psi. Pulls enough that now I gotta get a new clutch... Damn it. ECU tune, Injectors, intake (pepperoni has one in the gb), I would really suggest new SS lines cause you can really f... up threads on your block if not because the stock lines will need to be stretched a little. MAFS for sure cause your stock ain't going to hold it, a new clutch cause your little puny stock clutch ain't going to work, would suggest tires to put it down on the floor.... about all I can think of right now....
Old 07-31-2006, 04:00 PM   #18
boosteds13
boosteds13's Avatar
boosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really nice
Yep...
http://www.optionimports.com/gagtwigtstco.html
Although I am sure you can find it for a little cheaper if you do some searching around.
"A CA? WTF is that? You shoulda got an SR yo."
View my vBPicGallery!
boosteds13 is offline   Reply With Quote
Old 07-31-2006, 05:51 PM   #19
Dousan_PG
Dousan_PG's Avatar
t3/t4 turbonetics, i think .64ar?
is good for about 350ish to 400hp (max)
full boost by like 3500rpm? should be about that
full race manifold (new version)
44mm tial wastegate
'built' motor
and um...not sure on the tune yet, either PFC or ENTHALPY
should all be assembled and dynoed by end of august. motor in parts still. off to machine shop for head work shortly..
Aaron
Pink GodziRa
Old 07-31-2006, 08:59 PM   #20
fliprayzin240sx
Go PFC Dousan, if you can afford it...itll be better in the long run just cuz you can play with timing and such. Im running Enthalpy with SAFC piggybacked to it and im starting to wish i went with pfc so i have more control over the engine.
CLICK HERE!!!
Old 07-31-2006, 11:23 PM   #21
DrtyRat
DrtyRat's Avatar
DrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfection
LOL....sad but true
America... Too soft to place a killer in a well deserved tomb, But brave enough to kill a baby before he leaves the womb
DrtyRat is offline   Reply With Quote
Old 07-31-2006, 11:48 PM   #22
nsn240
nsn240's Avatar
nsn240 is on a distinguished road
Send a message via AIM to nsn240
i love this turbo, my good friend runs it on his car and it pulls like a mother fucker... just an example. this past sunday, 4-5 cars on a cammed, intake, exhaust transam, 1.5 cars when he sprayed a 150shot
Awesome turbo for the money and power it makes.
nsn240 is offline   Reply With Quote
