Old 07-31-2006, 08:42 PM   #1
alpalwal1
alpalwal1 is an unknown quantity at this point
Hole in the back of my block.... all bad *update with pics*
So I just put in my ka-t and when I was cranking it over I noticed a huge puddle of oil coming out from between the engine and tranny. after pulling the tranny and flywheel off I thought it was the main seal. Then, after turning the motor over by hand I realized it was a random hole in my block. It's about the size of a dime and is located at about 2 o'clock from the main seal. I have no clue what this is, but I need to cap it.. I see the hole in the fsm but it doesn't say anything about it.
HELP!
alpalwal1 is offline   Reply With Quote
Old 07-31-2006, 09:30 PM   #2
LA_phantom_240
LA_phantom_240's Avatar
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
sucks to be you... did you buy this motor from someone, or is this one you built yourself?
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 07-31-2006, 09:32 PM   #3
downshift_sideways
No Limit Soldier.
downshift_sideways's Avatar
downshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfection
Send a message via AIM to downshift_sideways
that is all bad.
what a pain in the ass to take off your tranny
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only"
downshift_sideways is offline   Reply With Quote
Old 07-31-2006, 10:02 PM   #4
aznpoopy
aznpoopy's Avatar
i have a stock '95 ka in my room.
i took a look behind the block. i think i see what you're talking about. there is a dime sized hole, and it's plugged by some kind of metallic insert. doesn't look like there's any way to take the plug out from the outside. it sits slightly recessed.
sorry i can't help more than that.
Old 07-31-2006, 10:11 PM   #5
kandyflip445
kandyflip445's Avatar
If it's a freeze plug you can go to the dealership and order one and install it. Good luck and I hope that's what you're looking for.
My 240 vBgarage
Old 08-01-2006, 06:26 AM   #6
LA_phantom_240
Thats it... i couldnt think of the name of the plug... freeze plug!
Old 08-01-2006, 09:39 AM   #7
shayrgob240
shayrgob240's Avatar
shayrgob240 is an unknown quantity at this point
Send a message via AIM to shayrgob240
so how would a freeze plug end up out of hte block? WHy would it come out?
shayrgob240 is offline   Reply With Quote
Old 08-01-2006, 10:18 AM   #8
alpalwal1
bump for pics.
oil is coming out of it, not coolant.
I'm more leaning towards oil galley right now but I don't know
Old 08-01-2006, 11:03 AM   #9
aznpoopy
aznpoopy's Avatar
take the pics and go to the dealership
it must be in their parts catalogue somewhere
Old 08-01-2006, 11:10 AM   #10
kandyflip445
The round brass things are the freeze plugs. Can you draw a arrow to the hole that's squirting out oil?
My 240 vBgarage
Old 08-01-2006, 11:52 AM   #11
trsilvias13
Looks like a freeze plug is missing to me.
Old 08-01-2006, 12:22 PM   #12
NemeGuero
No more nissan.
NemeGuero's Avatar
Bah! Jus' put some JB weld on that bish and keep driving!!
Old 08-01-2006, 07:26 PM   #13
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
It should be threaded, it (the plug) is ''allen'' type, I can check tomarrow and tell you for sure on that.
NIK90s13 is offline   Reply With Quote
Old 08-02-2006, 06:57 AM   #14
NIK90s13
NIK90s13's Avatar
Ok, I checked two diff. blocks this morning, the sr is threaded, that is what I thought of when i posted yesterday, the ka is just a plug.It looks like a steel dowl rod just hammered in. i sugest calling Nissan.
Old 08-02-2006, 07:01 AM   #15
orion::S14
orion::S14's Avatar
They (Nissan) have to drill the oil passages somehow, right?
Did this block have machine work done to it? Maybe it was removed and they forgot to reinstall.
Call Joel at HRT Machine (contact info can be found on KA-T.org)...he'll set you straight, and get you a plug if needed.
- Brian
www.KA24DEvelopment.com
Old 08-02-2006, 08:08 AM   #16
S14DB
AFC #1
S14DB's Avatar
For reference what it's supposed to look like with the plug in:
Old 08-02-2006, 09:32 AM   #17
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
I saw some plugs for sale on tt.net...
http://www.twinturbo.net/net/viewmsg...&msg_id=105611
rancid240 is offline   Reply With Quote
Old 08-02-2006, 12:07 PM   #18
nlzmo400r
nlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nice
Send a message via AIM to nlzmo400r
I would be worried as to why that plug came out. On a friend of mines ka-t, one of those plugs came out of the back of the head causing all of the coolant to shoot out and the engine overheated and warped the head; obviously the engine is dead now. So ask the previous owner as to why that plug was out of the block.
'my drinking team has a racing problem'
[email protected] - gt32 .6bar
nlzmo400r is offline   Reply With Quote
