Old 09-10-2006, 06:42 PM   #1
MAX Power SR
MAX Power SR is an unknown quantity at this point
s14 LOSING OIL??!!! Help
well i had just finished my build , sr s14, with new pistons, rings, rods etc. its been about 1200 miles since i finished it. well the car started to make noises, rattling like theres no oil and indeed there was barely any oil. i dont seee any smoke, leaks or anything. it smells a little like oil is burning but i dont know from where. WTF can this be. if it matters i had used Mobil 1 10w-30 synthetic oil. for now i just put in a qt of oil and the noise went away. any suggestions.
MAX Power SR is offline   Reply With Quote
Old 09-10-2006, 06:45 PM   #2
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
...did u build it yourself?
how much experience do you have with engine building?
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 09-10-2006, 09:39 PM   #3
MAX Power SR
im ase certified and was a mechanic for 4.5 years and have built approximately 45 motors, so i guess im pretty experienced.
Old 09-11-2006, 06:03 AM   #4
koukimonster139
<--ASE certified too!
Unless you have a small leak and you drive your car a lot and the oil burns off the side of the block before you get a chance to see it leak? I have no idea where ur oil is going if its not smoking or leaking.
ho ha ho chi chi
Old 09-11-2006, 06:59 AM   #5
MAX Power SR
yeah i checked for leaks and all that. i heard it was normal for performance cars to burn oil, especially turbo charged cars. my cousins sti needs about a qt and half in between every oil change. but i dont think it should be losing most of the oil like in my case.
Old 09-11-2006, 07:16 AM   #6
koukimonster139
is the back of your bumper black? that might be where all ur oil is going. its normal for high performance engines to burn a little oil, but not enough to make it rattle and be noisy. Has it been like this since you built it or just recently happening?
ho ha ho chi chi
Old 09-11-2006, 09:38 AM   #7
Gramentz
Gramentz's Avatar
Gramentz is making a name for him/her selfGramentz is making a name for him/her self
Check the turbo lines to see if anything appears wet in that area.
Fully Built
Gramentz is offline   Reply With Quote
Old 09-11-2006, 11:03 AM   #8
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
It's pretty notmal I built my motor too. and it does burn oil. but not as much. and it dosent make any noises it mightg be that the Oil you are using is too thin. since turbo cars run hotter you might need thicker Oil. I run Valvoline 20-W50 and only lost like half a quart betwen oil changes. (I;ve only done one oil change)
Review Thread
bardabe is offline   Reply With Quote
Old 09-11-2006, 01:06 PM   #9
SnakeKack
SnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of light
Send a message via AIM to SnakeKack
Check around the header. My 300zx was losing oil but there were no drips. It would drip out the valve cover and right onto the passenger side header and you wouldn't notice it unless you stuck your head in there right after shutting it off, it would burn and disapate and you could smell it and sometimes see a bit of smoke.
SnakeKack is offline   Reply With Quote
Old 09-11-2006, 03:03 PM   #10
MAX Power SR
today i decided to do a oil change. while draing approxiamtely 2 qts came out. filled with oil, Quaker state Synthetic 10w-30. Checked dipstick and it was full. Drove for while and felt much better and no noises. But now i realized there is smoke at times with heavy to medium accelration and it smells like oil burning. it doesnt smoke or anything at idle. idles perfect. no unusual noises or vibration. Can this mean that the turbo is going out? By that i mean like the seals. Or what else can it be?
Old 09-11-2006, 03:11 PM   #11
trybal
trybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymoretrybal is not welcome here anymore
Send a message via AIM to trybal
my turbo just coughs up smoke when i get on it. Insta smoke screen.. But i don't loost that much oil at all. And the smoke is deffinatly far from un-noticable
trybal is offline   Reply With Quote
Old 09-11-2006, 05:12 PM   #12
koukimonster139
mm could be a number of things:
so when u built the engine did u rebuild the turbo?
did u replace the valve seals?
im guessing it more than likely is one of these two things. also consider rings, breather, or guides.
ho ha ho chi chi
Old 09-14-2006, 09:30 AM   #13
MAX Power SR
did a compression test today
#1- 140
#2-140
#3- 140
#4- 140
put a little oil in each cylinder then retested
#1- 145
#2- 145
#3- 145
#4- 147
are these number normal for an s14 sr. keep in mind i have an 1.2 mm cometic head gasket
Old 09-16-2006, 05:09 PM   #14
Gramentz
Gramentz's Avatar
My motor is rebuilt with 600 miles on it and my comp. numbers are in the mid to high 150's....I thought you weren't supposed to use synthetic oil for a few thousand miles? Anyway, I believe that if your compression numbers go up when you put oil in the cylinders it means that your rings are either bad or not fully seated yet. How did you break in the motor?
Fully Built
Old 09-16-2006, 06:08 PM   #15
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
yea I dont know how true it is, but I have heard that synthitic oil is so thin that on a newer motor it can slip past the rings and burn a little bit of oil. Once the motor is fully broken it it can be run on synthetic oil.
I'm not sure on this though because most new cars come with synthetic oil from the factory. Maybe they break in the motors a bit prior to putting hem in the cars or something, but maybe this is part of your problem.
DJPimpFlex is offline   Reply With Quote
