Old 09-18-2006, 06:32 AM   #1
Josh K.
Josh K. is an unknown quantity at this point
MAP-ECU / MAF Eliminator
I have a used (wired into car but unused) MAP-ECU.
The MAP-ECU changes to a MAP based system and eliminates the MAF. also fully programmable fuel mapping with data logging capability. This unit is very popular with the Supra crowd and recently the DSM'ers. Will work with any MAF based system.
Comes with harness, air temp sensor, controller, software and a booklet with all related pdf's printed out.
Also I'm including 2 CNC Machined UHMW Plastic MAF Eliminators made by myself. they convert from the factory maf to either 2.5"OD or 3"OD (one of each included) pipe and bolt up to the stock aircleaner with the original 4 bolt maf pattern. all you need is a 2.5" or 3" pipe connected to the turbo.
I'm asking $375 +shipping. I paid $399 +shipping for the MAP-ECU plus the time to machine the adapters.
Josh K. is offline   Reply With Quote
Old 09-18-2006, 07:36 AM   #2
Cashizslick
Cashizslick can only hope to improve
What is the name of the system? Is it Defi-Link?
Cashizslick is offline   Reply With Quote
Old 09-18-2006, 08:56 AM   #3
Josh K.
MAP-ECU is the name.
www.map-ecu.com
Old 09-18-2006, 11:03 AM   #4
cc4usmc
cc4usmc's Avatar
wow...since when does defi offer something like that?
This forum requires that you wait 120 seconds between reporting posts. Please try again in 115 seconds.
Originally Posted by s141996 View Post
is this exhaust california friendly? thnx lmk
cc4usmc is offline   Reply With Quote
Old 09-18-2006, 11:22 AM   #5
bongnak
bongnak's Avatar
bongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of light
im guessing its brand new?
you never tried it out on your car. this sounds like a good product. take this and its functions and put it with a chipped ecu and you got yourself a pretty good setup; who wants to be the guinea pig?
Zzzz
bongnak is offline   Reply With Quote
Old 09-18-2006, 12:03 PM   #6
Josh K.
I installed it, made a base map and decided I don't really need 300WHP in Maui (I'm moving there next month). The air temp sensor wasn't installed and the electrical harness was shortened slightly to wire into my car.
It's a proven product. just establish a base map (it will auto learn from your maf signal). throw it on the dyno and tune the cells for the perfect AFR. no more MAF.
Old 09-19-2006, 04:03 AM   #7
Josh K.
Bump.........
