Old 10-05-2006, 01:44 AM   #1
imrickjamesbich
imrickjamesbich is an unknown quantity at this point
KA engine code 45 leaky injector?
does anyone know how the nissan ECU determines that the injector is leaking?
Also, it seems that my car is giving me a code 34. Its the one for the knock sensor. Related in some way to the code 45?
btw, checked injectors, not leaking. Thats why im so curious on how the ecu determines that an injector is leaking!
imrickjamesbich is offline   Reply With Quote
Old 10-05-2006, 09:29 AM   #2
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
Im guessing its a DOHC? Did you check the injectors by unbolting the fuel rail and then pressuring it up? Im not sure how the ECU determines leaky injector, but I had that along with an EGR code that I cleared when I found that my stock intake elbow was thrashed and replaced it.
rancid240 is offline   Reply With Quote
Old 10-05-2006, 09:36 AM   #3
i20ar
i20ar is an unknown quantity at this point
Send a message via AIM to i20ar
I dont kow how the car senses the leak.. i dont know how you checking but a good way is pull the fuel rail (with injectors still sealed in it) out of the motor but leave it compleatly attached to all the lines.. turn your car key to on(but dont start it) as if you were going to check your ecu code.. now watch the injectors as the pressure builds up if fuel constantly leaks from one of the injectors there you go.
when you drive does your car bogg or when at idle do the rpms drop and kill the engine? those are symptoms of leaky/bad injector
i20ar is offline   Reply With Quote
Old 10-05-2006, 11:12 AM   #4
imrickjamesbich
i did pressurize the system to check for leaking injector.
The car did die at idle once or 2wice. But it doesnt do it anymore. But CEL is stll present/
and yes, its dohc.
