Old 10-05-2006, 01:16 PM   #1
ONYX S-13
ONYX S-13's Avatar
ONYX S-13 is a name known to allONYX S-13 is a name known to allONYX S-13 is a name known to allONYX S-13 is a name known to allONYX S-13 is a name known to allONYX S-13 is a name known to allONYX S-13 is a name known to allONYX S-13 is a name known to allONYX S-13 is a name known to allONYX S-13 is a name known to allONYX S-13 is a name known to all
Send a message via AIM to ONYX S-13 Send a message via MSN to ONYX S-13
Shifter play (Very very sloppy)
(Yes i searched for "Loose shifter" results are here --> http://www.zilvia.net/f/search.php?searchid=923165 .. The only thread that had a reply didn't help me at all ---> http://www.zilvia.net/f/showthread.p...=Loose+shifter)
Here's a link to a video i took of it. http://www.youtube.com/watch?v=fR09iK9LrxE
This happened last week... On the way home from work the shifter felt really weird to where fifth and 2nd gear felt like there was like a ton of jelly in it that was actually hindering it from going in.. The feeling is really Numb in those gears.. I was fooling around with it last night , and there is also play when i push it down (In towards the tranny), like how a lot of new VW/Audi trannys are to get into reverse.. When i push it in and then put it into gear it feels a lot more normal... Maybe something broke that normally forces it down..? I can drive on it fine, it just feels really numb and trying to shift fast (especially into 5th) = Mis-shift cause it's so numb that i don't know if it's in gear or not. =/
ONYX S-13 is offline   Reply With Quote
Old 10-05-2006, 03:42 PM   #2
Bay_Area_sr20det
Bay_Area_sr20det is a well-known jackass
Send a message via AIM to Bay_Area_sr20det
if you take your shifter out, you will be able to see whats wrong. the shifter sticks into a small round hole, bropably broke something in thare. maby the plastic thing on the end of the shifter.
to take the shifter off just use a snap ring tool.
Speed Kills, Drive A Honda Live Forever!
Bay_Area_sr20det is offline   Reply With Quote
Old 10-05-2006, 04:50 PM   #3
DP_Michelle G
DP_Michelle G's Avatar
DP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really nice
when i had my ka my shifter was like that turns out that it was a bad trans mount
DP_Michelle G is offline   Reply With Quote
Old 10-05-2006, 04:57 PM   #4
slideways2004
slideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enough
Send a message via AIM to slideways2004
bad tranny mount. if your tranny mount is bad, most likely your motor mounts are bad too. so replace both at once and it will feel much moa bettah!
slideways2004 is offline   Reply With Quote
Old 10-05-2006, 05:04 PM   #5
ONYX S-13
ONYX S-13's Avatar
Thanks.. I'll take a look at it and do some shopping around for some mounts.
Hmmm.. But what does the mount have to do with the shifter? (Sorry for the lame questoions.. just don't know much about tranny's)
Old 10-05-2006, 05:22 PM   #6
redsuns3838
redsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the rough
Send a message via AIM to redsuns3838
just take off your shifter . (use some needle nose pliers) it takes 10 minutes and like someone said earlier u probly broke something down there and itll be aparent when you take out the shifter.
redsuns3838 is offline   Reply With Quote
Old 10-05-2006, 06:27 PM   #7
trsilvias13
it can be bad tranny mounts because it either crack or wearing out. You have to push down to engage because the tranny mount is not holding ( the tranny mount is right below the tranny)
Old 10-05-2006, 07:36 PM   #8
kandyflip445
kandyflip445's Avatar
There is a round bushing at the bottom of the shifter that, if worn out, can cause play when shifting gears.
The jello sensation can be caused by worn tranny/engine mounts. Like when you start the car and at idle the shifter just wobbles. You can either buy new mounts/nismo, syko (sp?), cusco/ or you can fill them with some urethane. If you search around for filling mounts you can find a few write-ups on it.
My 240 vBgarage
Old 10-05-2006, 07:40 PM   #9
LB.Motoring
LB.Motoring's Avatar
Yah, its a plastic bushing Cup.
here its at the bottom, maybe it cracked. If so, then its no a metal ball, and your shift cup so it will feel sloppy, chk this, heres a pic at the very bottom in white.
hope this helps.. I remmber this from a while ago. GL!
Robby Leuer
Old 10-05-2006, 10:10 PM   #10
Bay_Area_sr20det
[QUOTE=LB.Motoring]Yah, its a plastic bushing Cup.
ya thats exactly what i was talking about. thats probably it.
Old 10-05-2006, 10:10 PM   #11
Bay_Area_sr20det
Old 10-05-2006, 11:04 PM   #12
Flybert
You can also replace the springs on the side of the tranny below the shifter. Phase2 used to sell some that were made by HKS if I remember correctly. I also heard you can double up springs or put in your own that you find at home depot.
Old 10-05-2006, 11:31 PM   #13
xxxH28
xxxH28 is an unknown quantity at this point
http://www.youtube.com/watch?v=VH-qT6g-oGI&NR
xxxH28 is offline   Reply With Quote
Old 10-06-2006, 12:06 AM   #14
kandyflip445
Keep in mind if you install the new springs that when you put in a short shifter it will be even harder to move because of less leverage. When I installed my short shifter it was way harder until I drove around for awhile. And it is still stiffer than the stock now.
My 240 vBgarage
Old 10-06-2006, 02:58 AM   #15
Bay_Area_sr20det
what springs, i want em! any clue what exactly thare called?
Old 10-06-2006, 03:01 AM   #16
Bay_Area_sr20det
Originally Posted by xxxH28
MONEY!!! HAHAHA
Old 10-06-2006, 03:43 AM   #17
kandyflip445
http://storesense.megawebservers.com...ngs/Detail.bok
Link to the spring kit.
My 240 vBgarage
