Old 10-09-2006, 02:16 PM   #1
ronj
ronj is an unknown quantity at this point
How fast should a 2871R spool??
I have a few mods done to my car. I only push 10-11 psi out of a 2871r because I dont have any fuel manegment yet. I hit 10 psi at 4500 rpms. I thought it would be able to do 10 psi a little faster then that. I was hoping it would come on at around 3000 rpms at least.
MOD LIST:
HKS step 2 cams, 264 IN and EX
HKS valve springs
Crower titanium retainers
3 angle valve job
HKS rocker arm stoppers
Decked head
greddy intake manifold
greddy head gasket
Meagan racing turbo manifold
Garrett 2871R
greddy turbo elbow
blitz downpipe
cat delete pipe
Bee*R cat back
decked block
new rod bearings
new main bearings
ARP rod bolts
ARP Main studs
ARP head studs
Line bore done on block for the main studs to work
Honed cylinders and new piston rings
New oil pump
greddy oil pan
warlbro 255 fuel pump
greddy type s bov
nismo radiator cap
nismo thermostat
nismo motor mounts
nismo tranny mount
Koyo radioator
Flex a likte dual 12 fans and thermostat control
greddy oil catch can
greddy RSPL front mount
new oem nissan valves
new valve seals and guides
nismo shift knob
ACT 6 puck clutch
nismo slave cylinder
nismo braided clutch line
nismo clutch fork pivot
KYB AGX's
Eibach sportline springs
nismo power brace
JIC tension rods
JIC rear upper control arms
new power steering rack
new high pressure power steering line
relocated battery
90 seats, stock ones were SHOT!
18" rims
225/40/18 Yokohama ES 100's in front
275/35/18 Bridgestone Potenza S03's in back.
ronj is offline   Reply With Quote
Old 10-09-2006, 02:17 PM   #2
HyperTek
i think my friend said 320hp on his car which is simular setup i think same turbo etc
Keep it Classy
Old 10-09-2006, 02:20 PM   #3
LB.Motoring
LB.Motoring's Avatar
austin I think he was talking about when it starts to spool.^
get fuel manegment.com
hahaha I see the problem, you listed your seats in the mod list. it wont spool with those seats
Ive heard on sr's its roughly 3600/3800 rpm
what is this? 2871r .64 setup. ?
Robby Leuer
Old 10-09-2006, 02:49 PM   #4
ronj
HAHA, you like the seats dont you! The original ones had the matal bars popping out of them. It was pretty bad. Its a 2871r .64 ar
Old 10-09-2006, 02:52 PM   #5
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
Why do you spend so much money and not get the most important part of all? Get some tuning done. GetEr Done!
Jung918 is offline   Reply With Quote
Old 10-09-2006, 02:57 PM   #6
hybrid_eg
hybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the rough
.64 ar should have a much quicker spool.. mine came with a 10psi spring.. and spool was instant.. never really looked at the rpm as much but that thing practically had no lag at all.. i was running it on enthalapy ECU up to 19psi.. worked great!! never really ran it up that high.. but daily driven it on 1 bar.. and car made 305whp..
hybrid_eg is offline   Reply With Quote
Old 10-09-2006, 04:00 PM   #7
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
My gt28rs sees 10psi at like 3200, thats with a greddy stlye intake mani and no cams, there's no way you're gonna get 10psi on a 2871 at 3k
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 10-09-2006, 04:00 PM   #8
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Well first off, the turbos efficiency doesnt kick in till your closer to 1 bar. But 3K for that set up sounds bout right to hit full boost. Stock setup fully boost at roughly 3.5K with a .64 trim, add another 500 rpm for the .86 trim.
CLICK HERE!!!
Old 10-10-2006, 09:36 AM   #9
nsn240
nsn240's Avatar
nsn240 is on a distinguished road
Send a message via AIM to nsn240
yea that sounds right... 19psi ~35/3600
awesome turbo for a steet car, amazing power band
nsn240 is offline   Reply With Quote
Old 10-10-2006, 11:04 AM   #10
Id RaThEr DrIfT
Id RaThEr DrIfT's Avatar
Id RaThEr DrIfT is on a distinguished road
real quick can someone tell what turbo is beter . a T28rs or a 2871r?
witch one spools quicker?/can handle more whp?/and so on .. thank u !
"WhEn SoMeOnE yOu DoNt KnOw HaTeS yOu ThAtS wHeN yOu KnOw YoUr ThE bEsT"
Id RaThEr DrIfT is offline   Reply With Quote
Old 10-10-2006, 11:35 AM   #11
statik
statik's Avatar
real quick cuz youre lazy, gt28rs is good for about 320-40whp, think of it as a step up from a t28, spool comes on a few hundred rpm later, theres also a .64 and a .86(86 is the "disco potato"), id say the .64 is prolly only good for about 320, where as the .86 can make close to 350. The gt2871r in .64 is a step up from that, good for about 370whp, mayber coser to 400, the .86 is good for 400whp. All of these can do more on race gas and more boost but youre really maxing out the turbo. I've only had experience with the t25 and the gt28rs, but i've seen a few dynos on the gt2871r, so take it for whats its worth.
The gt28rs is a great turbo, spools incredibly fast (slower than a t25/t28 of course), and makes some fun power. The 2871r is also a great turbo, again its a quick spool for the power it makes, but slower than all of the previous turbos, which is expected for something that can put down 350+. I was hitting 18psi on the gt28rs at about 3400 on stock motor, its hard to unless you're in a taller gear with these size turbos. As previously stated, once the turbo gets to almost a bar its spools MUCH faster.
Old 10-10-2006, 01:33 PM   #12
Id RaThEr DrIfT
yeah a lil lazy haha thanx though ..
Old 10-10-2006, 02:12 PM   #13
steve shadows
steve shadows's Avatar
or you could do a divided top mount mani, divided turbine housing .63 ar turbine t3/to4e, 50 trim with BB centersection and spool up faster than a 2871r and make more max horsepower...
but thats a little mroe money...
EMS or standalones will allow you to tune properly for any turbo upgrade...
how far have you gone iwth your setup in regards to this?
Like Me on FaceBook !
