Old 07-08-2002, 05:30 AM   #1
Dark
Dark's Avatar
Dark is an unknown quantity at this point
For some reason I CAN'T remeber which is better <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/blush.gif" border="0" valign="absmiddle" alt=':blush:'>
Maybe the heat is getting to me &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''>
Hellllllllllllp :!:
93 Fastback, 5spd with obx shortshifter
Power is in the control of strength.
Dark is offline   Reply With Quote
Old 07-08-2002, 03:17 PM   #2
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
Well Viscous is a type of lsd.
Other types are clutch and mechanical.
Viscous operates like an open diff until enough wheelspin is created on one wheel to heat up a fluid tothe point where it become viscous enough to transfer some of the power to the other wheel. &nbsp;This is the best bet for a daily driver as it should be unoticable in regular driving and only apparent under heavy load/low grip situations and will probably work best in snow. &nbsp;it's also the cheapest
Mechanical and clutch type both start with a 50/50 split.
A clutch type uses clutches with a varying number of discs to determine breakway torque. &nbsp;Problem is a high breakaway that's good for keeping traction with lots of power on say a drag strip, will be hard to tolerate on the street and really challenging to parallel park as both wheels cannot turn at the same rate unless one is able to slip either at the diff or against the street surface. &nbsp;It's basically an on off diff. &nbsp;It will also be noisy and 2-3 times more money that the stock vlsd. &nbsp;example is KAAZ
A mechanical is torque distributing. &nbsp;The mechanics of it I do not fully understand but these are suppsed to be the best and are relatively unoticable to the driver. &nbsp;This is your (also the sytem employed by audi) quaife unit which will be as much or more than the clutch type and will be worth it for serious racing, though probably not worth the money as a street jobber. &nbsp;It also require some resitance to slip for mthe road surface so it will function like an open diff on some snow and ice from what I understand.
A dirt track racer will use a gold box (IIRC) which is effectively a welded diff when on the gas and an open diff when you get off. &nbsp;I don't know of any applications for the 240 as it's primarily a circle track only deal, but they are pretty darn cool and would make a great drift application as that's what they are essentially designed for.
Streetable- vlsd or mechanical
racing- clutch, mechanical, or welded
for cheap- vlsd
Steve
93 240sx FB currently very clean and for sale
240 2NR is offline   Reply With Quote
Old 07-08-2002, 03:26 PM   #3
sykikchimp
WOW addicted
sykikchimp's Avatar
clutch is streetable (Kaaz) you just get a clicking sound as you take tight corners, like parking, because of the clutch engaging, and disengaging.
Old 07-08-2002, 03:38 PM   #4
240 2NR
240 2NR's Avatar
Do you have one, and if so what is it set to? I would imagine that any good breakaway spec that would help in acceleration, especially a high hp car, would be too stiff for tight driving. &nbsp;I know the stock nissan clutch diffs only have 30ft-lb breakway, but adding one shim to it puts it over 100ft-lbs and at that point you might as well just weld the thing. &nbsp;Which seems to be the same on a KAAZ. &nbsp;If you can tolerate a harsh ride and lots of noise to get a stiff clutch engagement, you might as well save $900 and weld the diff. &nbsp;
Is it a one way unit, or does it disengage on decel and lift throttle? &nbsp;I'm assuming 2way, if it's 1.5 or 1 way it would make more sence to me.
Steve
Old 07-08-2002, 04:31 PM   #5
nczx2ner
nczx2ner is an unknown quantity at this point
granted i drive a fwd car but i have a phantom grip lsd conversion. &nbsp;It is a clutch type. &nbsp;It's not bad for street use. &nbsp;When I get on it thru a turn the car pulls the way that i steer. &nbsp;Before i would just drag ass. &nbsp;I haven't noticed any clicking noise. &nbsp;The lsd was 300 &nbsp;and to install it was 350
nczx2ner is offline   Reply With Quote
Old 07-09-2002, 03:02 AM   #6
SR20Fastback
SR20Fastback is an unknown quantity at this point
Send a message via AIM to SR20Fastback
wow 350 to install?
so a mechanical lsd would be the best bet for a daily driver/weekend racer kinda car? cuz thats what im looking for, for the next year and a half or so.
Fodive STILL blows goats, I have proof.
SR20Fastback is offline   Reply With Quote
