Old 07-08-2002, 07:46 PM   #1
halyoder
halyoder is an unknown quantity at this point
Send a message via AIM to halyoder
i have some diagrams from heavy throttle's web site but the colors on the wires are not the same and i think there diagram is for wiring up a 89 to 90 240 not a 91. please help if you have any info on this or know where i can get some info thanks.
www.zerolift.com
halyoder is offline   Reply With Quote
Old 07-08-2002, 07:51 PM   #2
halyoder
one other thing is on the end of my sr20 harness there are 3 plugs that plug in to the sr20 fuse box in the engine bay that are not on my 240sx fuse box. every thing i read doesn't say anything but to use my 240 fuse box. but were does the 3 plugs go to then?
www.zerolift.com
Old 07-08-2002, 11:31 PM   #3
Bolo
Bolo is an unknown quantity at this point
There are 3 plugs mounted to the inner fender, right next to the battery.  You will have to switch some wires around.  I have a 92 and the wire colors should be the same as yours.  I just followed the FAQ's on heavy throttle.  Good luck.
Rudy
Bolo is offline   Reply With Quote
Old 07-09-2002, 10:36 AM   #4
halyoder
i understand that but on the other side there are 3 plugs that pluged in to the fuse box from the sr but my fuse box does not have a spot to plug in to. the side that the fuse box i'm talking about is the drivers side. what do i do? :!:
www.zerolift.com
