Old 10-22-2006, 01:07 PM   #1
92-sr20-s13
92-sr20-s13 has a little shameless behavior in the past
How to check oil pressure
how would i go about checking engine oil pressure
92-sr20-s13 is offline   Reply With Quote
Old 10-22-2006, 01:08 PM   #2
ThatGuy
Admin Asshole
ThatGuy's Avatar
Old 10-22-2006, 02:18 PM   #3
McRussellPants
Warm up.
With the motor running remove the oil filter.
at 1000rpm it should take about 30 seconds before oil stops coming out.
longer than that and the pressure is tool low, faster than that and its too high.
at least thats how the FSM says to do it, the gauge works too if you have the money.
McRussellPants is offline   Reply With Quote
Old 10-22-2006, 02:51 PM   #4
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
You can check the oil pressure at idle and at about 3000rpm. I personally take the oil filter off with the engine stopped and then start the engine and rev it. It's not quite as messy.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 10-22-2006, 03:20 PM   #5
DRIFTER-M
DRIFTER-M's Avatar
DRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of light
Send a message via AIM to DRIFTER-M
the gauge is a good thing to have anyway if you have alittle $ to spend.
The way they are describing probably works as well.
Why do you need to know? If your pressure light is coming on when driving or flashing while driving you may be in a big hole. If it comes on every now and then when under 1k rpm or so, your oil pump is probably going bad, and if thats the case you need to fix it FAST.
DRIFTER-M is offline   Reply With Quote
Old 10-22-2006, 03:47 PM   #6
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
I hope no one actually does this.......
DJPimpFlex is offline   Reply With Quote
Old 10-22-2006, 04:00 PM   #7
ledzeppelin240
Well we will find out when there is a new thread made regarding engine being siezed. There are so many threads that explain how to check oil pressure and what the specs should be, someone should delete this thread.
Old 10-22-2006, 04:28 PM   #8
McRussellPants
Yeah, its not nessicary to check it, but its good to know that your oil pressure is on par, and the FSM says that the only way to do it is the way I described.
Old 10-22-2006, 05:22 PM   #9
Bay_Area_sr20det
Bay_Area_sr20det is a well-known jackass
Send a message via AIM to Bay_Area_sr20det
i have an oil press gauge, and i was wondering whare you tap it into, its electric. i was going to buy a filter relocation kit but im not gona spend the money right now.
Speed Kills, Drive A Honda Live Forever!
Bay_Area_sr20det is offline   Reply With Quote
