Old 10-25-2006, 12:13 PM   #1
OBEEWON
OBEEWON's Avatar
Turbo/exhaust Leak
OK Im getting really sick of taking my whole turbo assembly out. Ive done it like 7 times already. Im getting a leak where the manifold meets the turbo. I have a Megan manifold with a GT2871 and the studs keep loosening themselves. I have about a 2mm gap between the turbo and the manifold now. Its getting cold and I dont want to have to take this apart in the middle of the winter. What should I do to keep this tight?
Old 10-25-2006, 12:20 PM   #2
silverarrow27
silverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud of
You don't have the stock locking plates do you? Should buy a new set if you don't. Or try lock washers.
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd
silverarrow27 is offline   Reply With Quote
Old 10-25-2006, 12:40 PM   #3
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
mine was like that for awhile all i did was get locking washers
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 10-25-2006, 12:53 PM   #4
OBEEWON
OBEEWON's Avatar
I have the stock locking plates. The funnhy thing is that doesnt seem to make a difference. The whole stud seems to me turning out. What size are the locking washers, mine are getting stripped from taking it apart so much I might as well get some more. Will lock tight help at all?
Old 10-25-2006, 01:05 PM   #5
trsilvias13
I dont think lock tite would help much as the temperature on the manifold gets pretty hot (not sure though, but worth a try) or you can get new turbo stud, nuts, and wash from atp. Pretty cheap and good quality. The owner is a really cool guy as well.
Old 10-25-2006, 01:16 PM   #6
OBEEWON
OBEEWON's Avatar
My thinking exactly...
Do they sell the nuts and crap seperate? Because I already have new studs. Website?
Old 10-25-2006, 01:43 PM   #7
hiyaboa
hiyaboa is an unknown quantity at this point
Send a message via AIM to hiyaboa
if the back of the studs are visiable from the top side just tack(weld) them to the manifold....they wont come loose again
hiyaboa is offline   Reply With Quote
Old 10-25-2006, 01:48 PM   #8
OBEEWON
OBEEWON's Avatar
I like that idea.
Old 10-25-2006, 02:07 PM   #9
!Zar!
!Zar!'s Avatar
Just do it Jon Wayne style, and weld the turbo to the manifold.
Bust that baby loose.
Old 10-25-2006, 02:10 PM   #10
TheSquidd
TheSquidd's Avatar
I feel your pain brother. Lock washers, locking plates, torqued to hell, lock tite, and I still have bolts falling out. My suggestion is get downpipe with a flex section in it to help lessen the force of scraping your exhaust and get some good solid motormounts to keep the engine from vibrating and moving around.
TheSquidd is offline   Reply With Quote
Old 10-26-2006, 01:52 PM   #11
hiyaboa
i hated pulling the whole turbo/manifold off every couple months....so i just welded the studs to the manifold...bolted the turbo on...then tacked the nuts to the studs...works for me
Old 10-26-2006, 02:53 PM   #12
Creizai
Creizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura about
This sounds like a good fix to me
Creizai is offline   Reply With Quote
