Old 11-11-2006, 11:50 AM   #1
Gutling
Gutling is an unknown quantity at this point
Turbo Upgrade Question
Okay I had a decent build on my sr, but looking for more power. I am planning on finishing my block first.
Here is what the completed engine will have (including supp mods, not listing every little thing)
block - fresh rebuild, cp pistons, eagle rods, arp rod bolts, arp headstud kit, apexi headgasket
brand new head - hks step 1 264 intake/exhaust cams, hks cam gears, peak performance gold vavle springs, crower retainers, greddy rocker arm stoppers
greddy intake manifold, hks fuel rail, ???cc injectors (also looking for help for, if i use blitz everything above 550cc is low imp, will the power fc handle this or will i still need dsm resistor), walboro 255lph
apexi power fc, top mount mani, 3" exhaust, fmic, tial 38mm, hks ssqv, koyo rad, splitfire coilpacks, greddy pullys.
I am looking for 500+whp. NOT daily, daily maybe 400-450. But i want it to be there when i need it, I drag a lot, have never drifted or autox, not relaly planning to. just street/hwy/qtr mile. going to run d-jetro on the power fc, so no mafs. What turbo should i be looking for, my original plan was gt35r. plenty of umph to get 400 daily, and got 500 when i need it. any other suggestions/comments/ideas to help me? Also what are some good sites to look at for a turbo, most of them I have seen dont really show hp numbers. looking for help from ppl running similar setups, someones that done it and knows what to do/not to do.
Gutling is offline   Reply With Quote
Old 11-11-2006, 12:18 PM   #2
FrickU
FrickU has a little shameless behavior in the past
Maybe check with Jim Wolf Technology...They make amazing products. I have dealt with them a lot with G35 and 350Z turbo kits. I will be doing their turbo upgrade here pretty soon. Hope I could help
www.Kognitiondesign.com
1992 240sx
FrickU is offline   Reply With Quote
Old 11-11-2006, 12:50 PM   #3
GSXRJJordan
GSXRJJordan's Avatar
We used a Garrett unit very similar to a GT30R on the F-D S14 and it put down over 400whp at 18lbs, but that was an RB25DET, no cams, stock internals. The GT35R should be a good choice for you - also check out Precision's SC stuff, they do a lot of custom big hp turbos, and will definitely be able to help you out. Hybrid also has a special on their stuff goin on right now in the vendor section...
Old 11-11-2006, 01:39 PM   #4
Gutling
Thank you for the info guys, found this at Jim Wolf, I think its exactly what I am looking for
http://www.jimwolftechnology.com/cus...asp?PartID=439
Old 11-11-2006, 02:48 PM   #5
Gutling
PS
Still had my injector question, if I run with the hks fuel rail, and use blitz inj (lo imp) will the power fc work, or will i still need a dsm resistor? or is there another possible setup?
