Old 11-11-2006, 12:46 AM   #1
shayrgob240
shayrgob240's Avatar
shayrgob240 is an unknown quantity at this point
Send a message via AIM to shayrgob240
KA intake manifold question
do all KA24de intake manifolds have the butterfly vavles at the end of the runners? or is that only in the 91-94 models?
shayrgob240 is offline   Reply With Quote
Old 11-11-2006, 12:53 AM   #2
IngS14
IngS14's Avatar
IngS14 is making a name for him/her selfIngS14 is making a name for him/her self
Send a message via AIM to IngS14
only the FWD ka24de motor has butterfly valves on the runners,not on the 89-98 240sx ka24de motor.
IngS14 is offline   Reply With Quote
Old 11-11-2006, 01:20 AM   #3
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
91-94 240sx does have the butterfly for emission purposes.
http://www.240sx.org/faq/index.html
Jung918 is offline   Reply With Quote
Old 11-11-2006, 07:51 AM   #4
projectRDM
projectRDM's Avatar
All 91-mid93 RWD KAs have the SCVs, but it's not for emissions, it's to counter the loss of lower end power with the more aggressive 240/248 cams. When the cams went to 232/232 they deleted the SCVs since the power curve was more flat with the milder cams. Basically if you have SCVs, you have the better cams. 89-90 SOHC KAs use them too, same purpose.
Old 11-11-2006, 05:32 PM   #5
shayrgob240
so can I take them out? The reason why I'm asking is b/c I'm putting that motor in my 95 OBD II and I would rather keep everything the way it was before throwing in the rebuilt motor.
thanks for the good info
Old 11-11-2006, 05:37 PM   #6
projectRDM
projectRDM's Avatar
Pull them. Read up in here about the removal technique, I've discussed it before.
Old 11-11-2006, 05:44 PM   #7
undesiredshoe
undesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of light
Send a message via AIM to undesiredshoe
trust this guy, he knows almost everything there is to know about 240s
undesiredshoe is offline   Reply With Quote
