Old 11-25-2006, 01:58 PM   #1
idiot goes sideways
idiot goes sideways's Avatar
idiot goes sideways is an unknown quantity at this point
car dont idle
built up my ca18det and it doesn`t idle at all !!!
i can hold it only with the gas pedal and its strange like it response to the pedal
if i get of the gas it stalls, if i step on it lightly the engine rev up to 2000rpms (even with little throtle) and stalls again, if i pump with the throtle i can keep it from stalling but it rev up to 2000rpm`s again and stall again.
i cant keep the engine with the throtle at rpm`s, like 1500 ore 2000rpm`s it revs up alone and stall afterwards
the mods are
s15 turbo
power fc
534ccm injectors + fuel pump
z32 afm
270° tomei 8.80 lift cams
lighten crankshaft/ flywheel ( all togheter about 4,5 kilo less weight with pistons and rods)
forged piston/rods (compression ratio 8,2 :1)
mhg with studs
s15 turbo
with these mods it doesn`t idle and was backfiring heavy
to test i was going back to stock cams to figure out what the problem is,
the backfiring is gone now but it doesnt idle, like i wrote above
the a/f is right about 12,5 :1 under load
i cant realy check my ignition timing when car doesnt idle
also the self learning idle program from the power fc doesn`t work when the car is not idling
i checked the throttle body and the valve for idle
so the cams are not the issue...
could it be that ligthten the crank flywheel is the problem......
i`m starting to geting clueless, ive got not much experience with modified engines (my first moded engine) so anyone a clue??
idiot goes sideways is offline   Reply With Quote
Old 11-25-2006, 03:24 PM   #2
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
sounds like some sort of vacuum leak. Are you running a stock intercooler or aftermarket one? Check all the connections and make sure they arnt leaking air in.
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 11-25-2006, 04:26 PM   #3
idiot goes sideways
the lines are fine, and i run a aftermarket intercooler but drove this one with my stock engine ago so it should be okay
anyway if there would be air leaking in, the car would rev up alone and that doesn`t happend if i go of the throttle it stall`s................maybe i`m wrong
but i check for leaks, just in case,
any other ideas??
Old 11-25-2006, 05:55 PM   #4
ViZion Zs
ViZion Zs's Avatar
ViZion Zs is making his/her stupidity well-knownViZion Zs is making his/her stupidity well-knownViZion Zs is making his/her stupidity well-knownViZion Zs is making his/her stupidity well-known
wiring issue.. or a bad coilpack.
ViZion Zs is offline   Reply With Quote
Old 11-25-2006, 07:10 PM   #5
NemeGuero
No more nissan.
NemeGuero's Avatar
Sounds like your tune is crap for what you've built.
The vacuum lines may appear OK but do a pressure test on your IC piping.
