Old 11-27-2006, 07:46 PM   #1
drftnby
drftnby is an unknown quantity at this point
fuel and fuel tank questions!
i have and s14 and im about to finish my project and it has been sitting for about a year and half and besides being on my car trailor few times it really hasnt moved much and my question is should i be concerned wit how old da fuel is and should i take it our or leave it be, and also if i drain it, is there a drain plug on the tank or will i have to siphone the whole tank dry. i looked under the tank and dont see much dat resembles a drain so i really dont know wut i should do. i apprecaite it in advance!!
drftnby is offline   Reply With Quote
Old 11-27-2006, 08:18 PM   #2
dr.slide
dr.slide is an unknown quantity at this point
i would get rid of that fuel. just disconnect the sending line from the motor and pump all the fuel out using the fuel pump.
dr.slide is offline   Reply With Quote
Old 11-27-2006, 09:03 PM   #3
JDMClifford
JDMClifford's Avatar
JDMClifford is an unknown quantity at this point
Might want to run some fuel tank cleaner through it also. Maybe replace the fuel lines and fuel pump filter since your back there.
Parking lot pimping
JDMClifford is offline   Reply With Quote
Old 11-27-2006, 09:29 PM   #4
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
connecting a jumper to 30 and 87, on the fuel pump relay, is probably the easiest way to let the pump run. don't run the pump dry though.
g2ic02 is offline   Reply With Quote
