Old 11-27-2006, 10:15 PM   #1
xvr420x
xvr420x is an unknown quantity at this point
project car magazine
Has anybody seen this magazine i guess its new. Anyway the guy puts a sr20det in a s13 and says that the stock turbo doesnt need coolent to run right. He runs the t25 with no coolent. im thinking has anybody around here ever done this?
xvr420x is offline   Reply With Quote
Old 11-27-2006, 11:04 PM   #2
mrmephistopheles
mrmephistopheles's Avatar
It's common to run turbos without water cooling here in Japan.
It does reduce the service life of the turbo, but benefits the cooling system by reducing the possibility of boiling coolant and overheating the car.
OEMs use it because they need the engine to be as dependable as possible for as long as possible.
T25s? Who cares. They're $100 per, max.
Originally Posted by PHLIP
Old 11-27-2006, 11:13 PM   #3
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
the Blitz KKK turbo kit doesnt use water for cooling
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 11-27-2006, 11:24 PM   #4
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
I didnt even know turbos needed coolant... just oil, but from what mrmephistopheles said it all makes sense.
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 11-27-2006, 11:34 PM   #5
Dousan_PG
Dousan_PG's Avatar
some turbos do some dont
mine i just have oil
some run both
but imo
if u hav a turbo that has coolant AND oil you should run both
because the head that builds up. the channels and cooling is only on rather then too, so you cut the turbos life down quite a bit
depends on the turbo
i would run both if it has both
otherwise, doesnt matter.
Aaron
Pink GodziRa
Old 11-28-2006, 09:34 AM   #6
nsn240
nsn240's Avatar
nsn240 is on a distinguished road
Send a message via AIM to nsn240
what they said... oil is the necessary part, water is optional. Id say run the coolant lines if you can, or atleast loop the lines, so you dont have the coolant thats supposed to be moving through hit a wall
nsn240 is offline   Reply With Quote
Old 11-28-2006, 10:59 AM   #7
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
if you think about it, u have nothing to lose by running the lines, its just an added piece of mind plus if it was stock then your cooling system should handle it...
Slip Gypsies Blog
not sure if you realize this
Old 11-28-2006, 11:20 AM   #8
trsilvias13
Ball bearing turbo need coolant. Garrett will void your warrenty if you do not use it.
Old 11-28-2006, 09:53 PM   #9
TheWolf
TheWolf's Avatar
TheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant future
garrett will void your warranty if you look in the wrong direction at the turbo and don't make three virgin sacrifices to it at 8am every thursday. atleast on their GT turbos.
Eye on the Prize
TheWolf is offline   Reply With Quote
Old 11-29-2006, 07:24 AM   #10
spdfreek0o
spdfreek0o will become famous soon enoughspdfreek0o will become famous soon enoughspdfreek0o will become famous soon enough
Send a message via AIM to spdfreek0o
so upgrading to an only oil cooled turbo on an sr isn't sacralige?
spdfreek0o is offline   Reply With Quote
Old 11-29-2006, 01:19 PM   #11
anyotherone
anyotherone is a splendid one to beholdanyotherone is a splendid one to beholdanyotherone is a splendid one to beholdanyotherone is a splendid one to beholdanyotherone is a splendid one to beholdanyotherone is a splendid one to beholdanyotherone is a splendid one to beholdanyotherone is a splendid one to beholdanyotherone is a splendid one to beholdanyotherone is a splendid one to beholdanyotherone is a splendid one to behold
This is very true... I bolted a brand-spankin-new GT35r to a customers car that went bad in 100 miles of driving with pretty much no boost whatsoever and they wouldn't warranty it.
anyotherone is offline   Reply With Quote
