Old 11-28-2006, 11:19 AM   #1
insanequickness
insanequickness has a little shameless behavior in the past
no reverse lights!
ok i know there is a sensor on the tranny...
so if its plugged in then the sensor is bad correct?
anything else cause this?
insanequickness is offline   Reply With Quote
Old 11-28-2006, 03:10 PM   #2
cotbu
cotbu's Avatar
NO! your bulbs could be blown or a short in the wiring!
Old 11-28-2006, 04:27 PM   #3
'90RPS13
'90RPS13's Avatar
'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute
Send a message via AIM to '90RPS13
Look at all the red squares in here? Damn. Kinding wondering if I should be in here. LOL. Naw, like he said, check shorts in the wire or possible blown bulb. *a
'90RPS13 is offline   Reply With Quote
Old 11-28-2006, 06:45 PM   #4
mrmephistopheles
mrmephistopheles's Avatar
check the freakin' fuse first.
fuse first
then bullbs
then sensor.
Originally Posted by PHLIP
Old 11-28-2006, 09:06 PM   #5
insanequickness
well ive obviously checked the most obvious...
the bulbs are new...
wiring looks fine...
Old 11-28-2006, 09:33 PM   #6
'90RPS13
'90RPS13's Avatar
Smarting off to Kev is not the wisest. Should have stated it in the main post. *a
Old 11-28-2006, 09:42 PM   #7
NemeGuero
No more nissan.
NemeGuero's Avatar
How do you know the bulbs are fine? Put a voltage across them and see if they light up.
Did you really check the wiring? Continuity test? Or did you just look at it and say "yeeupp.. thats some good wiring."
Old 11-28-2006, 09:50 PM   #8
TipStylez
TipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enough
It means, get clear taillights.
TipStylez is offline   Reply With Quote
Old 11-29-2006, 12:11 AM   #9
mrmephistopheles
so have you checked the fuse or not?
You didn't say that you have.
Drop your attitude, it's unneccesary.
