Old 12-02-2006, 02:21 PM   #1
karazycrakr
karazycrakr is an unknown quantity at this point
starting uo problem
okay so i swapped a sr into my s13 and replaced the timing chain, tensioners and guide along with oil pump, water pump and put 255 walbro fuel pump so im trying to start it up and ive checked eveything i know of but it wont start. it pops and sputters thats about it, it has fuel and spark and everythin is plugged in. Anyone have any suggestions??
thanks
Graham
karazycrakr is offline   Reply With Quote
Old 12-02-2006, 02:25 PM   #2
MURPHY
MURPHY's Avatar
MURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfection
Send a message via AIM to MURPHY
did you set the timing right?
MURPHY is offline   Reply With Quote
Old 12-02-2006, 07:09 PM   #3
karazycrakr
yes the timing is set right
Old 12-02-2006, 07:47 PM   #4
cotbu
cotbu's Avatar
It's probably the timing if you have fuel and spark!
Here, set #1 piston to TDC, then pull out CAS. If its set right? rotate crank again til TDC come up again.( don't over shoot TDC) Install CAS per FSM. It should fire if mechanical timing is right.
All that means is timing is off about 180deg or somthing like that. GL
If mechanical timing is wrong it could be wrong in many ways.
Old 12-02-2006, 10:20 PM   #5
cmcdougle
cmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to behold
Send a message via MSN to cmcdougle
Are you positive you have fuel? are the injectors firing? Are they squirting fuel? You could have reversed the fuel lines if they aren't. The fuel should flow from the back to the front on the injector side of the fuel rail. Are the vacuum lines connected to the Fuel Pressure Regulators and to the fuel tank? Are your plugs gapped .039-.043? Do you have spark on all 4 cylinders? Is the fuel pressure 36 PSI?
Go to Pep Boys (or your auto parts store) and buy a timing light. They are $40 or so. Find piston #1 (usually closest to front of car), and hook up the clamp to the spark plug wire. Connect it to the battery properly, and find the white mark on the Crank pulley and the engine. Have a friend crank the car. The light should turn on when the engine hits Top Dead Center (when the white marks match up). If they do, then the timing should be right.
Start eliminating causes of the problems so you can narrow it down a bit.
cmcdougle is offline   Reply With Quote
