Old 12-06-2006, 01:46 PM   #1
Kallikak
Kallikak's Avatar
Kallikak can only hope to improve
Clutch not disengaging...
Over the past few days, I noticed the clutch on the Nissan was feeling softer, gradually getting worse. It was disengaging further and further through the stroke. Yesterday, I get in to leave to school, start it, push in the clutch, and try to engage reverse...it won't go. The clutch isn't disengaging fully, which means I had to slam the shifter into reverse, accompanied by the sound of angry synchros, in order to position it so I could jump-start the Chevy. I went to try to move the Nissan this morning, slammed the thing in reverse, and the damn thing is moving even with the clutch to the floor. Shit...I essentially have no use of the clutch pedal. I'm not sure what is wrong; I'm thinking the clutch master cylinder or slave cylinder. I was thinking I was just low on fluid, but there is plenty of fluid in the reservior (albeit, nasty, old and possibly original fluid.) Anyone ever experience this who could confirm my suspicion?
Kallikak is offline   Reply With Quote
Old 12-06-2006, 02:04 PM   #2
storey
storey is an unknown quantity at this point
i had something similar with my s13. i was losing fluid though. i noticed a small puddle under my car so i check my clutch slave cylinder and sure enough the o-ring inside was broken.
storey is offline   Reply With Quote
Old 12-06-2006, 10:51 PM   #3
smelly240
smelly240's Avatar
the fluid has a lot of water (turning it black - thats how hydraulic fluid works) absorbed in it - bleed it no matter what
you might have air in it - a bad part - or something like that - first i would look for wetness, and then bleed teh clutch. I had a similar problem in winter before it was weird - after parking the car - and letting it sit a week and a half - then starting and driving, the clutch disengaged less each time as i went towards the gas station... i think water evaporated out of the fluid and then upon cooling froze in a bubble - and then when it got hot became compressable again.
Old 12-06-2006, 11:36 PM   #4
Mathetai
Mathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to all
If you noticed the pedal soggy and gradually got worse to not even engaging/disengaging, I would say its your clutch MC no doubt. When you step on the pedal, it pushes the fluid down the lines and forces the SC to open up. When it goes bad, the piston in the MC doesnt move hence the fluid doesnt get pushed. I have had the same problem in 2 prior cars with the exact symptoms your having. When replacing this part, dont cheap out and buy used unless you know its in good condition. I would just buy a brand new one and save the headaches. Good luck dude.
Mathetai is offline   Reply With Quote
Old 12-09-2006, 07:42 PM   #5
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
slave cylinder.. get a new one....
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 12-09-2006, 10:57 PM   #6
drew935
drew935's Avatar
drew935 is making a name for him/her selfdrew935 is making a name for him/her selfdrew935 is making a name for him/her self
welcome to the club
I'm driving fast
-drew
drew935 is offline   Reply With Quote
Old 12-10-2006, 01:05 AM   #7
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
wont disengage, rad! I hope I dont have that issue. Mine is feeling sketchy.
Edit:
possible issue. Seized throwout bearing. AKA, instead of turning it wore through the clutch plate. (worst case senereo)
most likely: fluid issues, bleeding and checking lines might help. Maybe the piston isnt ligned up with it anymore. You can eyeball it if you lay down next to the car.
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 12-10-2006, 01:30 AM   #8
TKfoshori
TKfoshori is a well-known jackass
Send a message via AIM to TKfoshori
just dont get the cheap vatozone ones, made in taiwan b.s. if you do you'll be getting another in a couple months.
For Sale
TKfoshori is offline   Reply With Quote
Old 12-10-2006, 02:41 AM   #9
newblood
newblood's Avatar
newblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond repute
Send a message via AIM to newblood Send a message via MSN to newblood
Talking
me and my friends have had that happen and it's just the return spring on your clutch peddal just pull it back up and it should be perfect!
street drifter 9000!
newblood is offline   Reply With Quote
Old 12-10-2006, 06:35 PM   #10
ms!3
yea its probably the sc. this happened on one of my buddies miata. does this also happen when its cold out side? sorry to thread jack but i dont wanna start a thread for this but i started my car up one morning and put it in reverse and it kept going back into neutral and when i pressed in the clutch it took longer than what it usually does to disengage( thought it was sc going out too) but it kinda fixed itself when the car warmed up. first time if been driving mine in the winter so i thought id ask.
ms!3 is offline   Reply With Quote
Old 12-11-2006, 08:37 PM   #11
infinitexsound
its because the piston on the slave is sticking... because of worn rubber seal, bad return spring.. etc etc etc just needs a rebuild...
Old 12-19-2006, 01:45 AM   #12
ka24kingmannyd
ka24kingmannyd's Avatar
ka24kingmannyd is a well-known jackass
Send a message via AIM to ka24kingmannyd
s13
ha man i have the same car same color and....yes same problem till this point....
idk what year ur car is but if you look under your car theres going to be like a lil damper block where all you clutch lines meet well on top of it theres gonna be an extra one bleed that one and you should get good pressure....
what i used to bleed my car without two people is a water bottle what did was i made a hole in the lid and put any kinda car hosethrew the lid and put it on the nozzle and open the nozzle and bleed you car pump it 5 times then refill ur MC and them pump it 5 more times and re fill do this two more times dont take of the hose untill you have tighen your nozzle!
GOOD LUCK HOPE IT WORKS !
it worked for me ....but it my clutch losse pressure after a couple of weeks so i know its getting air from somewhere i think i need to replaced that nozzle!
lol sorry i wrote alot but im just tryin to help here!!
ka24kingmannyd is offline   Reply With Quote
