Old 12-07-2006, 10:02 PM   #1
ctnotts
ctnotts is an unknown quantity at this point
adding ABS?
hey whatsup guys, i was wanting to know the parts required to ADD abs... im sure i could find the parts cause' everybody seems to want to take it out.
My car is a 91 hatch with a redtop SR, any help would be appreciated
Daily Driver : 2005 Scion Tc
My Project : 1991 240sx Fastback, rust bucket full of rice! Now with an SR
YEAHHH!!!!!
ctnotts is offline   Reply With Quote
Old 12-07-2006, 10:37 PM   #2
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
You'll the need the following items to install ABS in to your 240:
The ABS system uses an ABS Actuator which is located right behind the passenger side strut tower on the fire wall (a pain in the ass to disconnect, btw).
Then there's the ABS control unit which is located somewhere near the rear driver side wheel on an S13.
You may need to have a specific brake master cylinder to support the ABS actuator.
Additionally, you'll need all the harness plugs, sensors, and brake hardlines.
To tell you the truth I think this project will be a pain in the ass. Besides, the 240's ABS isn't that great to begin with.
If you're still determined to go through with it the section dealing with the ABS system is located on page BR-20 in the KA S13 FSM and on page BR-24 in the SR S14 FSM.
Good Luck.
HalveBlue is offline   Reply With Quote
Old 12-08-2006, 07:33 PM   #3
azndummie
azndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant future
I thought that if you plugged the fuse into the slot marked ABS, then it would work?
Now, why would you want ABS? It is really hard to add and is a lot of work. It's not worth it.
azndummie is offline   Reply With Quote
Old 12-09-2006, 08:49 AM   #4
spdfreek0o
spdfreek0o will become famous soon enoughspdfreek0o will become famous soon enoughspdfreek0o will become famous soon enough
Send a message via AIM to spdfreek0o
This won't work on cars not equipped with ABS. You need the entire ABS system. Adding ABS is going to be more work and very little benefit if any. The system isn't the greatest so people remove them to be more effecient.
spdfreek0o is offline   Reply With Quote
Old 12-09-2006, 09:30 AM   #5
TipStylez
TipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enough
Yeah, why would you want ABS?
TipStylez is offline   Reply With Quote
Old 12-09-2006, 03:40 PM   #6
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
lol i had an abs car and i pulled the fuse...
anyway i have some abs parts lying around, if youre really wanting it, i have the controller, actuator and bmc....
aNskY is offline   Reply With Quote
Old 12-09-2006, 04:02 PM   #7
los_inc
los_inc's Avatar
los_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond repute
Send a message via AIM to los_inc
find an s13 with abs and skip the hassle
los_inc is offline   Reply With Quote
Old 12-10-2006, 06:40 PM   #8
ms!3
from what ive heard the s13 abs isnt really that good. lol you could probably make a better abs system by pumping the brakes yourself.
ms!3 is offline   Reply With Quote
