Old 12-13-2006, 08:18 PM   #1
CA18_S13
CA18_S13's Avatar
CA18_S13 is a well-known jackass
Where is this broke wire suppose to go?
KA24DE
1993 SE model Coupe
Just got my alternator changed didn't know where this broken wire is suppose to go cause it was like that before i changed the alternator? The black wire with yellow stripe is the ground wire. The skinny black wire coming off the loom is one that goes to back of the alternator. The other black thing is a ziptie.
CA18_S13 is offline   Reply With Quote
Old 12-13-2006, 10:19 PM   #2
smelly240
smelly240's Avatar
is there a big wire hooked to your alternaor? it looks like the one that goes to the alternator and usually has a ===(o) on the end.
maybe the alternator wasnt bad???
Old 12-13-2006, 10:21 PM   #3
CA18_S13
CA18_S13's Avatar
yeah maybe that was the frayed wired i saw. Well so what do i need to do crimp another same gauge wire and then get a connecter on there.
Old 12-13-2006, 10:23 PM   #4
CA18_S13
CA18_S13's Avatar
well i brought the old alternator to advanced and they said the bearing were coming loose and it rattled on the test machine
Old 12-13-2006, 10:27 PM   #5
smelly240
smelly240's Avatar
bearing dont make the stator windings short to ground tho - was it charging th ebattery? my guess is thats the output wire from the alternator - and your battery was goin dead after a few days?
Old 12-13-2006, 10:29 PM   #6
CA18_S13
CA18_S13's Avatar
Yeah so is that a stator plug or is it just a =O connector like this.
Old 12-13-2006, 10:30 PM   #7
CA18_S13
CA18_S13's Avatar
If it is please show me a best picture of where that bolts too
Old 12-13-2006, 10:36 PM   #8
smelly240
smelly240's Avatar
there should be a plug on the alternater, a wire for gnd and a wire thats fused and eventually goes back to the + on ur battery... check ur pm's
Old 12-14-2006, 10:27 AM   #9
drew300zx
drew300zx is making a name for him/her selfdrew300zx is making a name for him/her self
looks like a ground, the wires coming off the alternator are as follows, black-ground, white goes to fuse box then to batt, then the white with red strip goes to the interior fuse box
drew300zx is offline   Reply With Quote
Old 12-14-2006, 10:38 AM   #10
smelly240
smelly240's Avatar
there are 4 wire on a KA alternator
Old 12-14-2006, 12:08 PM   #11
CA18_S13
CA18_S13's Avatar
i connected it to the alternator and it was making the charge better so it connects to the altenator
