Old 12-14-2006, 12:40 AM   #1
shane_lxi
shane_lxi's Avatar
shane_lxi is an unknown quantity at this point
Fucking A! ca18det mbc, anybody run one?
Okay. Lol, this is pissing me off now. I bought a perrin boost controller. I've installed many a mbc in my time, but for some reason the one I put on my car wants to be a pain in the ass. I cut the vac line to my wg and put in the controller. It brought my boost up, but no matter if I open it all the way, or closed it all the way, it would still boost way to high (about 16psi) then cut off. I tried flipping it the other, maybe I put it in wrong? No, if I do it that way I cant adjust my boost up or down, it just runs factory pressure, 6-7psi. So I was thinking maybe I have my wg hooked up to a shitty vac source? If anyone is running a ca18det with a mbc, please tell me if I should use a different vac source! I am only trying to reach about 12psi. Thanks a bunch.
there is another nipple directly below the throttle body too, but it is a little smaller then the nipple i have the actuator connected to right now. The smaller nipple is blocked.
shane_lxi is offline   Reply With Quote
Old 12-14-2006, 12:56 AM   #2
originalsin
originalsin has a little shameless behavior in the past
i run my wastegate off one of the lines that runs behind the motor, the factory one.
wat kinda vac are you pulling at idle?
originalsin is offline   Reply With Quote
Old 12-14-2006, 01:04 AM   #3
shane_lxi
shane_lxi's Avatar
I am running 16-18 vac at idle right now. I have the vac line behind the mani hooked up to my boost gauge, I suppose I could switch the two tomorrow and see what happens. Are you running an mbc on your ca18?
Old 12-14-2006, 04:57 AM   #4
Wykydtron
Wykydtron's Avatar
Wykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really nice
The actuator line is suppose to be coming off of the charge piping before the throttle body, not after.
@schassis.eddi
Wykydtron is offline   Reply With Quote
Old 12-14-2006, 12:46 PM   #5
shane_lxi
shane_lxi's Avatar
Then I will move it . Thanks ed.
Old 12-14-2006, 05:32 PM   #6
shane_lxi
shane_lxi's Avatar
Shit, swtiched it to the nipple right below the throttle body and still nothing has improved. Took it out for now, when the weather gets better I'll try and figure it out (110mph winds tonight )
Old 12-14-2006, 08:28 PM   #7
Arther3
Arther3 is an unknown quantity at this point
could you explain why it makes a difference?
Arther3 is offline   Reply With Quote
Old 12-14-2006, 08:57 PM   #8
kuramaya
kuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfection
I dont see what the problem is as long as you have one Vac line to the Intake manifold and one to the acuator like my setup here:
ZEROYON WEBSITE IS HOMO
NEW SITE: blacklinux.com/innersanctum/index.php
kuramaya is offline   Reply With Quote
Old 12-15-2006, 07:39 PM   #9
shane_lxi
shane_lxi's Avatar
Yeah. Mine is inline. I had a line running from my actuator to the intake side, and I just severed it and put the mbc inline. But it wont adjust, it just always boosts to 15psi before cutting off :P.
Old 12-15-2006, 08:14 PM   #10
yokotas13
yokotas13's Avatar
i have a line going from the chargepipe going to the TB, to the boost controller.
yokotas13 is offline   Reply With Quote
Old 12-16-2006, 12:29 AM   #11
shane_lxi
shane_lxi's Avatar
Thanks for your replies. I'm going to try welding a nipple on my cold pipe next wednesday (sadly, my next day off ) and seing if that works better. If not, I'm just going to have to assume I have a faulty mbc, nothing else is working and I have tried every vaccuum port available :P. Does anyone on here run a mbc with their ca18 setup who might be able to help? I've gotten lots of help from the sr guys .
Old 12-16-2006, 01:16 AM   #12
originalsin
it comes off the back of the intake manifold from the factory
Old 12-16-2006, 02:58 AM   #13
shane_lxi
shane_lxi's Avatar
They are running sr's too, so that might make a little difference as far as vacuum locations go too. I'll try using the source on the back of the engine too. I currently have my boost gauge on that. I tried it earlier, but with a tee on that line, so I'll just dedicate it to the mbc and see what happens .
Old 12-16-2006, 03:03 AM   #14
badboy6686
badboy6686 is an unknown quantity at this point
dude i would say that the MBC is installed correctly the way that ended up with stock boost, then you need to adjust it until you have it right where you want it. If you install it and its pegging out your boost gauge then that's a clue that it is obviously backwards and not letting the wastegate get a signal. I wouldn't go through welding a new port for vacuum as i'm sure your source is more than adequate
badboy6686 is offline   Reply With Quote
Old 12-16-2006, 03:10 AM   #15
Wykydtron
Wykydtron's Avatar
BOV's, Boost Gauge and FPR use vacuum.
Wastegates (Internal/External) operate on pressure.
Both work, but why rob from a vacuum source?
@schassis.eddi
Old 12-16-2006, 08:50 AM   #16
boosteds13
boosteds13's Avatar
boosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really nice
I think what he's getting at is that it shouldn't affect the operation of the MBC.
To the original poster, I have my MBC hooked up to the same place you do and mine works fine. Try taking the MBC apart. On some, the spring binds up and gets stuck. Either that or they messed up and put too stiff of a spring in it.
"A CA? WTF is that? You shoulda got an SR yo."
View my vBPicGallery!
boosteds13 is offline   Reply With Quote
Old 12-16-2006, 07:26 PM   #17
shane_lxi
shane_lxi's Avatar
I have tried it on every single available vacuum port, flipped both ways, adjusted at what is supposed to be stock, at what should be less than stock, and what should be more then stock. Basically I have covered every scenario already. When I had it installed and it worked at stock boost, I tried adjusting it with no results. It actually seemed to spool a bit quicker, but my boost stayed at 6-7 psi. I have pretty much tried everything, including taking it apart (which the warranty says not to do :P ). I was thinking the mbc was faulty, but how many things could be wrong with it. idk, I'll try some more ish tomorrow.
Old 12-16-2006, 07:31 PM   #18
badboy6686
You are over compliacting the situation, the MBC is faulty, replace it and it will work.
Old 12-17-2006, 01:23 PM   #19
Hugh
Hugh's Avatar
Hugh is on a distinguished road
I've had this happen with an MBC before, one from Turbosmart. It boosted max all the time, no matter what. It's a bad piece, and I got screwed on Ebay buying it used. (seller probably had the same exact trouble with it)
As far as vacuum source for boost goes, you should connect it to the hot pipe.. not the cold pipe. The compressor outlet or just after will give you the best response for boost control, making the turbo hit maximum boost faster and more dependably.
Many turbo setups (OEM and aftermarket) sense boost from directly out of the compressor outlet for this reason.
I have a nipple welded to my hot pipe that goes to my EBC for this.
1973 Datsun 240z powered by SR20DET/Tec3
Site Admin of http://www.zeroyon.com
Hugh is offline   Reply With Quote
Old 12-17-2006, 08:51 PM   #20
shane_lxi
shane_lxi's Avatar
Spring was no good/too stiff. I actually pulled one out of an ink pen, and messed with it for a while. Works great now, sitting at 12psi with a 14psi spike. Not too bad, right about where I wanted to be . Thanks for the help. I thought spending $90 on a boost controller instead of $14 would be a good idea, lol. I guess I was mistaken :P. Stupid Perrin :P.
