Old 12-26-2006, 01:35 AM   #1
JDMClifford
JDMClifford's Avatar
JDMClifford is an unknown quantity at this point
DD/mountian driving sway bars
So I've Ben looking for some aftermarket sway bars. I'm not to sure what to get. I'm not going to drift this car since its my DD. I'm looking for more for a setup witch will let me handle the mountain roads better. My price range in around $300 because i need to also buy a new steering rack this week. The reason I'm not sure what to buy is because i have Ben reading certain ones are for drifting.
This is what i have Ben looking at. Will it work for what I'm looking for?
Suspension Techniques Front and Rear Sway Bar Set Nissan 240sx 89-94. Front Bar Diameter 1 1/16 inch, rear bar diameter 13/16 inch.
http://storesense.megawebservers.com...and/Detail.bok
__________________________________________________ _________
and should i get aftermarket end links while I'm down there?
Parking lot pimping
JDMClifford is offline   Reply With Quote
Old 12-26-2006, 01:40 AM   #2
HyperTek
yes they should work since you said you dont want something too stiff
Keep it Classy
Old 12-26-2006, 02:05 AM   #3
JDMClifford
alright cool thanks for the help
Parking lot pimping
Old 12-26-2006, 03:32 AM   #4
JDMClifford
i was also looking at the GODSPEED anti sway cars, they are alot cheeper.
FRONT- 30.05mm
REAR - 28.29mm
-Full Chromemoly Construction, Handling Master
-Bolt On, Stock Mounting
-No Adjustment Necessary
-Solid Bushings Included
what is the differance? just quality? and why would these be crap compared to the other ones?
Parking lot pimping
Old 12-26-2006, 03:36 AM   #5
TipStylez
TipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enough
^Didnt someone do a review on that here?
I also wanted to know about them.
TipStylez is offline   Reply With Quote
Old 12-26-2006, 03:54 AM   #6
JDMClifford
i couldnt find anything.
Parking lot pimping
Old 12-26-2006, 04:08 AM   #7
Anto
Anto's Avatar
Anto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfection
Nooooo
The Godspeed sways are chromoly tube & they are crush bent instead of mandrel bent.
I was seriously considering getting these bars, but I realized that the rear bar was WAY thick. The front/rear ratio gets all out of wack & would probably create massive oversteer.
I think i'm going to go with the ST ones. Best bang / Buck
Anto is offline   Reply With Quote
Old 12-26-2006, 04:24 AM   #8
JDMClifford
not mandrel bent? what crap!. well thx for the info, saved my ass.
Parking lot pimping
Old 12-26-2006, 05:51 AM   #9
Replicant_S14
Replicant_S14's Avatar
Replicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of light
What difference does it make?
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink.
Replicant_S14 is offline   Reply With Quote
Old 12-26-2006, 09:32 AM   #10
Irukandji
If you can find it, you can always get a hicas rear sway bar. It's much cheaper than most aftermarket sway bars and is close to the same diameter.
Old 12-26-2006, 12:22 PM   #11
Wei240
Wei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really nice
and be careful which hicas you get it from
usdm hicas = 21mm
jdm hicas (on some models, i think just the 89-90 models) = 17mm
stock ones = 15mm
i had all three
Wei240 is offline   Reply With Quote
Old 12-26-2006, 12:54 PM   #12
!Zar!
!Zar!'s Avatar
Blah blah blah. Whiteline. You can adjust them.
And there isn't a huge need to upgrade the end links. So you can save a little money.
And remember, most stuff marketed for, "drifting" and what not is just regular performance parts. Named to appeal to a certain crowd.
If you do go the cheaper way, as said by n1sm0r, get a hicas rear bar.
And while you're at it, get a hicas steering rack. Better steering ratio imo.
Old 12-26-2006, 12:55 PM   #13
OptionZero
OptionZero's Avatar
stock bars from an S14 SE with upgraded endlinks (ball joints) would probably make a big difference, Turdz was considering making his own and IIRC found that the price is favorable to purchasing new ones.
You can always ask SPL or any largus dealer if u wanna shell out some cash
Stock bushings will probably reduce the effectiveness of any bigger sway bar you get.
Just a thought, haven't done it myself.
Old 12-26-2006, 12:58 PM   #14
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
There is also Tanabe and Largus anti-sway bars. The Tanabe ones should be around your price range.
Jung918 is offline   Reply With Quote
Old 12-26-2006, 01:25 PM   #15
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Whiteline makes nice sway bars, I am very satisfied with mine. I got mine from PDM iirc.
MELLO*SOS is offline   Reply With Quote
Old 12-26-2006, 01:50 PM   #16
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Yeah, can anyone answer why the godspeed bars wouldn't be fine?
I already have s/t bars on my s13, just curious.
Alex
e1_griego is online now   Reply With Quote
Old 12-26-2006, 02:00 PM   #17
chuy
chuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura about
I got Tanabes and love them spent a day looking for the endlinks though.
Slide Happy
chuy is offline   Reply With Quote
Old 12-26-2006, 02:28 PM   #18
RPS13FREAK
RPS13FREAK has a spectacular aura aboutRPS13FREAK has a spectacular aura aboutRPS13FREAK has a spectacular aura aboutRPS13FREAK has a spectacular aura aboutRPS13FREAK has a spectacular aura aboutRPS13FREAK has a spectacular aura about
I used to have Largus sway bars F & R. They are really thick, but super super super lightweight. If you set the front sway on the first hole understeer goes away. They made the car feel a lot more solid on the mountain roads & when my car would oversteer it felt very controllable. I can't really say anything about daily driving because my car was rough on the streets since I would keep my coilovers on medium to hard dampening.
SHIFT_zilvia
RPS13FREAK is offline   Reply With Quote
Old 12-26-2006, 04:28 PM   #19
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
I heard the R32 rear sway bar is like 25mm or 27mm thick and bolts up...you might research that a bit and try hitting up a Skyline chat board's "for sale" section.
-m
400x200
mbmbmb23 is offline   Reply With Quote
Old 12-26-2006, 04:36 PM   #20
Gilboyto
Gilboyto is making a name for him/her selfGilboyto is making a name for him/her self
I think whitelines are good, but can also be expensive. I just put the Suspension Techniques on mine, got both for a steal. Summit had them for $240 for front and rear kit. I noticed a huge increase in the rear especially, and the front doesnt roll as much either.
Heres some pics of them installed incase you wanted to see...
Heres the rear with endlink...
Heres the front comparison:
And heres the front with the endlink:
Gilboyto is offline   Reply With Quote
Old 12-26-2006, 04:50 PM   #21
SoSideways
SoSideways's Avatar
That green is awesome. And the red bushings = good bushings
Old 12-26-2006, 08:44 PM   #22
Kaizen.
Kaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymore
I love my suspension techs!
Kaizen. is offline   Reply With Quote
Old 12-26-2006, 08:50 PM   #23
Irukandji
Sweet xmas sway bars.
Old 12-27-2006, 01:37 AM   #24
JDMClifford
wow they dont look much biger than stock is it really worth the money?
jsut for a referance i have front/rear strut tower brace, rear under brace, front power/under/subframe or whatever brace, c pillar bar, Tokico blues and cut stock springs. would i notice biger swaybars? and its an s13 btw.
Parking lot pimping
Old 12-27-2006, 01:50 AM   #25
JDMClifford
ohh, also jsut wondering if the 300zx bars or s14 bars will fit?
sounds like s14 se bars fit, but what about aftermarket s14 bars on an s13 or aftermarket 300zx. and would i not want to go to stiff? would it cause me to just slide out?
Parking lot pimping
Old 12-27-2006, 01:51 AM   #26
!Zar!
!Zar!'s Avatar
You would notice that your car's suspension is crappier than it already is.
First purchase real suspension and get rid of those blow shock and ghetto modded springs.
Sway bars will make a HUGE diff in how your car handles.
And did you miss EVERYTHING said in this thread?
Edit: ghsajgnwq; ;kaqspghal
Damnit.
I said it before and I'll say it again.
Sway bars aren't ment to stiffen your car.
They stop body roll. And they help maximize your contact patch.
Stop being so fucking ghetto
Do it rite or don't do it at all. Because all you are going to do is trash up your car worse than it is.
Old 12-27-2006, 02:27 AM   #27
JDMClifford
I know the sway bars don't stiffen my car up, from the way i understand they try apply the highest percentage coupling between both sides, and to increase the spring rate on the side is compressed the most.
Do it rite or don't do it at all. Because all you are going to do is trash up your car worse than it is.[/QUOTE]
oh and i am asking because i want to do it right and take the "fucking ghettoness" out of it. So im buying good quality sway bars, new shocks and lowering springs. Theres no way im going to put coilovers on my dd. A to expensive and B not worth the money its not a race car, its a sports car.
Also my car is not trashed. thanks for the help on telling that i would feel a huge difference of the aftermarket sway bars. I appreciate it.
Parking lot pimping
Old 12-27-2006, 04:23 AM   #28
TougeNinja
TougeNinja is making a name for him/her selfTougeNinja is making a name for him/her selfTougeNinja is making a name for him/her self
what do you mean by "the first hole"? the one farthest out from the actual bar? or the one buting right up to actual bar.... thx in advance!
TougeNinja is offline   Reply With Quote
Old 12-27-2006, 05:04 AM   #29
TipStylez
Quick thread jack.
What would be the best setup for a full grip setup?
Old 12-27-2006, 09:38 AM   #30
nevaland9
nevaland9's Avatar
nevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfection
Send a message via AIM to nevaland9
Originally Posted by TipStylez
Quick thread jack.
also interested
nevaland9 is offline   Reply With Quote
