Old 12-29-2006, 03:17 AM   #1
duckeee322
duckeee322 is making his/her stupidity well-knownduckeee322 is making his/her stupidity well-knownduckeee322 is making his/her stupidity well-known
rear end popping noise. PLEASE HELP!
when i jerk my tranny around
i can hear a popping sound in the back of my car
i knew my tranny mount was bad
so i changed that today
nismo mounts
but it still did the same thing
and so i jacked up the rear end by jacking up the diff.
and i saw the whole back end suspension shift
it looked like they werent supporting the rear (whatever you call it, suspension)
http://img.photobucket.com/albums/v4...gerside_02.jpg
http://img.photobucket.com/albums/v4...gerside_01.jpg
http://img.photobucket.com/albums/v4...verside_02.jpg
http://img.photobucket.com/albums/v4...verside_01.jpg
it looks like theres too much spacing. i have no idea what the parts are called or whatever.
i need help. its pissing me off badly. please help with anything.
**UPDATE**
i figured it was my subframe bushings.. thanks for the link!
alright. for the vibration. here's the story. i never really had this problem before. i lowered my car with some tein lowering springs my friend gave me for the time being. thats when i noticed a lil vibration. i checked under the car and i saw that my stock tension rod bushings were broken so i changed those. i bought kazama tension rods and installed them. but that only made my vibrations worse. i have gotten my tires balanced and it didnt work. do you really think i just need an alignment?
duckeee322 is offline   Reply With Quote
Old 12-29-2006, 03:20 AM   #2
240mph
240mph's Avatar
240mph is making a name for him/her self240mph is making a name for him/her self
Send a message via AIM to 240mph Send a message via MSN to 240mph
It's called Subframe bushings.
240mph is offline   Reply With Quote
Old 12-29-2006, 08:32 AM   #3
duckeee322
lol thanks. do you think that space right there is normal?
the whole rear end drops maybe like an inch when lifting it by the diff.
the other thing is, would this make my car shake when reaching speeds of like 70-80 mph? i feel the vibrations from the front.
Old 12-29-2006, 01:46 PM   #4
180sx Fan
180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all
the vibration from the front is probably caused by a shitty alignment or not balanced wheels
And if the subframe itself dropps an inch when you lift it up that is not normal and your subframe bushings are worn out.
180sx Fan is offline   Reply With Quote
Old 12-29-2006, 02:18 PM   #5
idlafie
idlafie's Avatar
Duckee....
Click on the attached link on information on ordering & replacing your rear subframe bushings.....Something I posted about 2 weeks ago.
http://www.zilvia.net/f/showthread.php?t=128132
ID
Old 12-29-2006, 02:30 PM   #6
!Zar!
!Zar!'s Avatar
You should get subframe collars. Bushings are a pain to install.
That will fix the rear end problem.
You should get your tires balanced. Vibration comes from your wheels needing to be balanced. But get an alignment also just because chances are you are long over due. And you have a slight drop.
Old 12-29-2006, 06:22 PM   #7
Eddie@Performance
Eddie@Performance's Avatar
Eddie@Performance is making a name for him/her selfEddie@Performance is making a name for him/her self
Send a message via AIM to Eddie@Performance
You might have blown shocks as well, that also contributes to unwanted vibrations/shaking/hopping
And 2nd on subframe bushing instal being a PITAl....get the spacer collars, they are easy to install, inexpensive, and very effective
Eddie@Performance is offline   Reply With Quote
Old 12-29-2006, 10:09 PM   #8
duckeee322
thanks guys. actually i checked all the shocks, made sure they were alright and double checked on the installation. everything seems fine. the only thing i can think of is getting an alignment now. but can the vibrations be this bad with just an alignment problem?
Old 12-30-2006, 12:42 AM   #9
Eddie@Performance
If the tires are worn out funny it definitely can, my Kumho Ecsta MX does this, almost feels like rolling on offroad truck tires from the vibations.
Old 12-31-2006, 10:03 PM   #10
Teknolust72
Teknolust72's Avatar
Trader Rating: (40)
Teknolust72 is a splendid one to beholdTeknolust72 is a splendid one to beholdTeknolust72 is a splendid one to beholdTeknolust72 is a splendid one to beholdTeknolust72 is a splendid one to beholdTeknolust72 is a splendid one to beholdTeknolust72 is a splendid one to beholdTeknolust72 is a splendid one to beholdTeknolust72 is a splendid one to beholdTeknolust72 is a splendid one to beholdTeknolust72 is a splendid one to behold
Feedback Score: 40 reviews
When does it vibrate when you are going 70-80 mph? Are you accelerating/decelerating, going straight or slightly turning? How is the road; slight bumps or smooth like glass?
Teknolust72 is offline   Reply With Quote
Old 01-03-2007, 09:53 PM   #11
duckeee322
umm i dont have to accelerate or anything. it does it on its on. accelerating or decelerating, it doesnt matter. any road condition too. it still vibrates.
and yes, my tires are worn down. you think thats a problem?
Old 01-03-2007, 10:22 PM   #12
Creizai
Creizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura about
80% of the time it is the rear shocks blown.
Creizai is offline   Reply With Quote
Old 01-04-2007, 06:29 AM   #13
duckeee322
i've checked those. this weekend im installing kazama subframe spacers. think that'll help?
Old 01-06-2007, 08:07 PM   #14
Teknolust72
Trader Rating: (40)
Do you have power steering? I had vibration like yours when my power steering pump crapped out. Even though I was going straight on the freeway, it would vibrate, and then stop a mile later, but it would happen again later on.
