Old 12-29-2006, 04:53 PM   #1
ilovecoupes
ilovecoupes's Avatar
ilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to behold
head unit problem
Okay, I’m on my third head unit now. I put a new the head unit utilizing a wiring harness. I was left over with a speaker amplifier and a radio ground. I had no sound. So after some searching I read about speaker amplifiers. so I tried by passing the "active" amplifier in the front speakers by matching:
the blue w/yellow front left neg -
the blue w/white front left pos +
the brown w/white stripe is front right pos +
the solid brown is front right neg -
I still have no sound!
also, I don't know if this affects any thing but a mute wire was left over on the headunit side
Thanks in advance
ilovecoupes is offline   Reply With Quote
Old 12-29-2006, 06:01 PM   #2
Blackhat
Blackhat is an unknown quantity at this point
What year car?
Did you cut past the stock radio connector? They make adapters for the harness that would make this real easy.
I'll assuming the HU is actually powering up? May want to look in the FSM wiring diagrams to find out what the deal is with the stock amps. You may want to just bypass them.
Blackhat is offline   Reply With Quote
Old 12-29-2006, 06:38 PM   #3
harleys
harleys is an unknown quantity at this point
more than likely no stock amp. hopefully you didn't cut your factory plug off, becuase like he said above, they make a plug that plugs into it. nissans dont have a ground wire, so you just have to take the black wire coming out of the back of the radio and ground it to the chassis of the car. easiest way is to put a ring terminal on it, and screw it to any piece of metal. if you need any more help, just let me know.
harley
harleys is offline   Reply With Quote
Old 12-30-2006, 10:01 AM   #4
Ross73
Ross73 is an unknown quantity at this point
connect the speaker amplifier wire from the car to the speaker amp control wire from the new head unit, you will get sound, your not getting any sound because your stock amp isnt turned on, if you dont wanna use the stock amp run your own speaker wires through the car.
Ross73 is offline   Reply With Quote
Old 12-30-2006, 11:39 AM   #5
ilovecoupes
I have the factory amp (little circuit board behind the speaker), so I tried to bypass it by using the existing wires as my speaker wires. and I cut before the plug. The car is a 93 240 SE
Originally Posted by Ross73
connect the speaker amplifier wire from the car to the speaker amp control wire from the new head unit, you will get sound.
there is no hook up for this on the head unit. I tried splicing the amplifier wire into a wire with a 12v source and just got a little sound from the rear right speaker.
any help is appreciated
Old 12-30-2006, 02:20 PM   #6
Ross73
if you dont have an amp control wire from the HU hook it up to the antenna control wire see if that does it.
Old 12-30-2006, 02:34 PM   #7
Ross73
also get a multi-meter and beep test the wires at each speaker for continuity, i dont think you hooked them up right, the stock wiring can be a mess if your not sure what your doing, you might be better off running your own wires.
Old 12-30-2006, 02:35 PM   #8
Ross73
if you connected the speakers right as a streight through wire amp or no amp they would produce sound.
Old 12-30-2006, 03:00 PM   #9
ilovecoupes
i ran my own wires from one speaker to the head unit and still no sound. i tried putting the amp wire into the two power antenna wires; still no sound. I think it might me my cheap walmart harness thats bad. if its not that i give up and letting tweeter do it. also i there is a mute wire on the head unit side that has no matching wire.
