XS power-Exhaust Manifold Rebuilding.
Okay so I just bought this XS Power exhaust manifold for 80$ and I plan on putting it on my new setup. I am wondering, is it worth it to send it to a welding shop to be cut apart at the welds and rewelded. The welding looks a little suspicious. Does anyone know how much a welding shop would charge to do this, I dont care about the look of it, as long as they're sturdy and dont cause turbulence inside the runners.
I also plan on fabricating a bracket to my turbo elbow off the block to reduce exhaust manifold strain so its not all resting on the manifold. Cliff: Is it beneficial to have a SSAC/XS Power manifold rewelded at a welding shop. |
I wouldnt bother, but it depends on the use of the car and how hard you push it. Id just wait until it cracks and have the crack welded shut.
keep your stock mani handy for when that happens. |
![]() Join Date: Oct 2006
I have a xs power manifold on my blacktop..its a top mount setup, with a 2871r the welds on mine are really good..and a buddy of mine was tire of buying new manifolds for his EVO so he bought one off ebay too..hes putting down like over 400 to the wheels..been holding up for months now. so i think you'll be alright..jus do what redsuns said deff. keep ur stock mani around you never know. good luck
-Evan |
#4 | |
![]() Join Date: Jan 2006
thats retarded. why would you even buy it then? with what your going to pay to have it cut, ground, rewelded, ground again and polished you could have bought a decent mani by now. btw if you are going to be "fabricating" a bracket to the elbow then why cant u play legos with the mani urself instead of taking it somewhere? ![]()
ho ha ho chi chi |
Rick (Ghost-Dancer) cut his up and rewelded it. He said once you fix the welds it will last you a long time. Ask him next time you see him online
@schassis.eddi ![]() |
![]() Join Date: Nov 2004
If you have the means, cutting it and rewelding it would not be a bad idea. I was talking to a guy at golden gardens last year with a xs power mani on his sr'd 510. He had nothing but complaints about the welds. But, about 3 of my friends up here in washington run xs mani's with no problems. Run it as see what happens if you cant afford the rewelding.
#9 | |
#10 | |
I got the manifold for 80$ brand new so it wouldnt kill the bank to pay like 200$ to have it cut and rewelded, I wont have them worry about appearance tho, as long as the welds are strong
Well, I personally think that it would be better to spend the money on a nice flexpipe & make sure your exhaust hangers & motormounts are in good condition. Hell.. solid motormounts even..
AFC #1
![]() Join Date: Oct 2003
If mine ever breaks I'll just buy another off eBay. Have to buy 5 or more to come to the cost of a brand name manifold.
Hell, when I get some extra money I'll just buy one and leave it on the shelf as cheap insurance.
#15 | |
#16 | ||
Flex pipe is highly recommended for tubular type manifolds, the 300ZX suffers the same problem with tubular manifolds, they crack after a while because of the lack of flexibility. Stock cast iron units are alot stronger and can withstand the movement but tubular type manifolds are alot thinner material gauge so it tends to crack more easily. Flex pipes arent expensive, they cost less then Ebay manifolds, so why not get them? Quote:
I personally dont like the idea of a solid aluminum motor mount, someone made one for the 300ZX as well but every bolt and nut on the car starts to come loose, and fall off. I think a Nismo, or a urethane mount should do well enough for most applications. |
