Old 01-04-2007, 11:03 AM   #1
KAs14slider
KAs14slider is making a name for him/her selfKAs14slider is making a name for him/her selfKAs14slider is making a name for him/her self
Help Identifying turbo
Hi guys, I bought a turbo recently for my KA-T build. It was advertised as a stock t-25 but I don't think it is. It says Garret m-24 on the side and ar. 80 Anyone know what turbo this is? Here is a pic:
[/img]
Also, I was wondering if the turbo is bad because when I try to spin the compressor, it won't spin easily. I have to try hard to spin it. I don't know much about turbo's. Does this mean the turbo is dead, or will it spin fine when hooked up to the oil lines and installed on the car, or should it spin easier in one direction than the other?, any help would be appreciated. I was always under the impression that you should be able to easily spin the turbo with your hand.
Thanks Alex.
KAs14slider is offline   Reply With Quote
Old 01-04-2007, 11:26 AM   #2
Wei240
Wei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really nice
that's one clean ass used turbo...
i'll go home and check mine since it's out and ready for sale,
but mine spins freely, both ways, no shaft play,
you shouldn't have to be struggling to spin it,
yours is possible busted, but it's journal bearing, it's rebuildable, probably 100-150ish??? not sure...
Wei240 is offline   Reply With Quote
Old 01-04-2007, 08:40 PM   #3
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
could of just got a t3 and called it a day.....size is comparable to a t25.... check the sizing of the housings and shit like that.... small turbo tho...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 01-04-2007, 09:59 PM   #4
chibo
chibo's Avatar
chibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfection
Send a message via AIM to chibo
I had one of those on my old SR20, I think it was a t25. Never got a definitive answer out of anyone here when I posted mine. I'll tell you that with an intercooler and 3" downpipe back I made 250rwhp/275rwt at 10psi and a 3* retard in timing. With a turbo elbow, 3" straight pipe, tune, 12psi, and correct timing I was making over 300 at the wheels.
chibo is offline   Reply With Quote
Old 01-04-2007, 10:49 PM   #5
KAs14slider
So it's basically busted if it won't spin freely? Someone was telling me that it might just be gummy oil build up and that the most important thing to look for is no shaft play. I don't know if they are right though.
Old 01-06-2007, 10:02 PM   #6
iiEddieGii
iiEddieGii is a well-known jackass
Send a message via AIM to iiEddieGii
After doing a little searching, I found this on Wikipedia, which says that is a t25g turbo (shown below). Seems to be just the stock s13 red top turbo.
iiEddieGii is offline   Reply With Quote
Old 01-06-2007, 11:28 PM   #7
S14DB
AFC #1
S14DB's Avatar
Man, that compressor wheel has a bunch of sludge on it. Pics of turbine side?
Old 01-07-2007, 03:50 AM   #8
JDMClifford
JDMClifford's Avatar
JDMClifford is an unknown quantity at this point
thats what my stock turbo says on it. s13 redtop
Parking lot pimping
JDMClifford is offline   Reply With Quote
Old 01-07-2007, 06:07 PM   #9
GSXRJJordan
GSXRJJordan's Avatar
yes, thats a stock s13 redtop turbo, and yes, it's bad that it doesnt spin freely. It's true that it could be buildup in there - you can try spraying some degreaser in the oil holes and through the blades and spinning it by hand for a while, but theres no guarantee that the turbo's not toast.
