Old 05-22-2006, 07:09 PM   #1
sblack13
sblack13's Avatar
sblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud of
sr main crank pulley question
i have a question. Are the s13/s14/s15 sr20 motor's, the crank pulleys are the same right? Looking are some pulleys on ebay, i would assume they are the same though. Just double checking thanks.
I also would appreciate it, if anyone has any input on anymarket crank pulleys for a s14 sr20. Whats the difference over stock?
sblack13 is offline   Reply With Quote
Old 01-06-2007, 07:07 PM   #2
JDMClifford
JDMClifford's Avatar
JDMClifford is an unknown quantity at this point
I need the same question answered. Except im not gonna go on eBay.
Parking lot pimping
JDMClifford is offline   Reply With Quote
Old 01-06-2007, 07:09 PM   #3
S14DB
AFC #1
S14DB's Avatar
Don't get one.
Old 01-06-2007, 07:12 PM   #4
JDMClifford
i have no choice mine broke. due to my stupid gear puller being stutpid.
Parking lot pimping
Old 01-06-2007, 07:33 PM   #5
MavericStephenc
MavericStephenc's Avatar
MavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfection
Send a message via AIM to MavericStephenc
i think jgycustoms.com has them
MavericStephenc is offline   Reply With Quote
Old 01-06-2007, 07:38 PM   #6
MavericStephenc
http://jgycustoms.com/240sx/underhood.htm
btw here it is
Old 01-06-2007, 07:46 PM   #7
S14DB
AFC #1
S14DB's Avatar
Only difference is if you have a HICAS PS pump or not. 4 Ribs on the Hicas, 3 on non Hicas. Just have to get the same PS pulley as the crank ribs.
I have never seen gains from CRANK pulleys personally. The arguments about harmonics and damping with no gains is good enough for me to stay away from them.
I would like one of these once I have some cash. http://www.atiperformanceproducts.co.../damnissan.htm
Old 01-06-2007, 07:48 PM   #8
vrooompssssht
vrooompssssht is not welcome here anymorevrooompssssht is not welcome here anymorevrooompssssht is not welcome here anymorevrooompssssht is not welcome here anymorevrooompssssht is not welcome here anymorevrooompssssht is not welcome here anymorevrooompssssht is not welcome here anymorevrooompssssht is not welcome here anymorevrooompssssht is not welcome here anymore
Originally Posted by S14DB
. The arguments about harmonics and damping ]
so thats how they balance the motors huh?
vrooompssssht is offline   Reply With Quote
Old 01-06-2007, 08:05 PM   #9
S14DB
AFC #1
S14DB's Avatar
Did I mention Balance?
Old 01-06-2007, 08:31 PM   #10
withy
withy is an unknown quantity at this point
Send a message via AIM to withy
how much do those dampers cost? i couldn't find aby prices
withy is offline   Reply With Quote
Old 01-06-2007, 08:33 PM   #11
S14DB
AFC #1
S14DB's Avatar
Summit was like $300-350 IIRC.
Old 01-06-2007, 08:40 PM   #12
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
I have a stock crank pulley in perfect condition if u want it.
Review Thread
bardabe is offline   Reply With Quote
Old 01-07-2007, 12:45 AM   #13
MavericStephenc
the way i see it is a lighter crank pully water and ps pully will in some ways (not much) allow for a quicker spool in terms of rpm ,much like a light weight flywheel. you can also get more efficent cooling by using a larger of smaller or larger water pump pully (one pushes more water faster and the other allows for a slower flow but better cooling when it gets to the radiator) but thats getting off topic. also in terms of belts, (you might know this) dont buy a belt and cut ribbs to make it fit www.mynismo.com carries the sr20 belt set for around 50 bucks.
that was alot longer than i intended
Old 01-07-2007, 01:52 AM   #14
McRussellPants
The only pully kit I've seen designed to work with the ATI damper are the Naprec ones.
One guy that posts here has Naprec pullies, i don't know if they're the ATI damper type
McRussellPants is offline   Reply With Quote
Old 01-07-2007, 03:46 AM   #15
JDMClifford
thx for all the info. im looking at a bunch of brands. all seem sketch except a few. and bardabe you have a PM.
Parking lot pimping
Old 01-07-2007, 05:01 AM   #16
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
I had an ASP IIRC crank pulley. Seemed to free up tension and become more responsive, but i wouldn't say any gains.
SochBAT is offline   Reply With Quote
Old 01-07-2007, 05:13 AM   #17
S14DB
AFC #1
S14DB's Avatar
That's the other problem I had. I can find the Damper but not the Pulley that bolts to it. The Naprec set deletes AC and under drives everything. Total race setup.
