Old 01-09-2007, 02:25 PM   #1
nismosil40zx
nismosil40zx is a well-known jackass
Send a message via AIM to nismosil40zx
SR SR20DET Transmission Question
Alright I was driven yesterday and pull out of fifth and it felt like it just brought everything with it. Like it was pulling on something? I made it home Shut it off and started it back up. Well I started it uP In neutral and car is in neutral so I thought, but when i let off of the clutch it goes into reverse(while shifter stays in neutral when i put the car in any forward gear it just boggs and dies. Car drives fine in reverse and I have no direct drive nothing. Could this simple be fixed my just changing out bell housing w/ a ka tranny or do you guys think it it something else? Thanks
nismosil40zx is offline   Reply With Quote
Old 01-09-2007, 03:42 PM   #2
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
thats weird..
sepulchral is offline   Reply With Quote
Old 01-09-2007, 05:21 PM   #3
amp2345
amp2345 is not welcome here anymoreamp2345 is not welcome here anymoreamp2345 is not welcome here anymoreamp2345 is not welcome here anymoreamp2345 is not welcome here anymoreamp2345 is not welcome here anymoreamp2345 is not welcome here anymoreamp2345 is not welcome here anymore
Send a message via AIM to amp2345
this does sound pretty serious , even if that plastic piece at the bottom of the shifter did disenegrade it woudl shift altho do check to make sure its there...all you need to do is remove the C snap ring and shfiter will pull out. there should be a plastic bushign snapped on to the end.
as far as changing the bellhousing with ka tranny i am actualy going to do/try that friday so hit me up and i will tell you how it goes.
amp2345 is offline   Reply With Quote
Old 01-09-2007, 08:00 PM   #4
nismosil40zx
thanbks any other info on that swap that i may run into a problem with?
