Old 01-10-2007, 01:01 AM   #1
yokotas13
yokotas13's Avatar
s13 alarm install
Ok so i have an alarm here, its an Excalibur, dont remember the exact model number ill edit this later with more info.
I got the remote start to work, but i cant get the door lock unlock to work (only have an orange/black wire and black, not hte ones its saying i should) or the shock sensor.
Anyone know anything im bypassing that is pretty universal that isnt letting this stuff work?
Also where do you guys connect the wire for the safety signal? i just grounded it, i guess i can try the ebrake as well for hte turbo time option.
yokotas13 is offline   Reply With Quote
Old 01-10-2007, 12:01 PM   #2
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
For the locks you have to hook up a actuator in the drivers door that operates the lock/unlock rod of the original actuator. Because when push the lock/unlock thing it then triggers the actuator to lock/unlock both doors. I will have to double check to make sure that is right.
What do you mean by safety signal???
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 01-10-2007, 02:11 PM   #3
yokotas13
yokotas13's Avatar
shit i forgot to update this. When i wake up tomorrow ill take care of it, and give a detailed display.
i have the door open hooked up wrong also for some reason
