Old 01-17-2007, 04:11 PM   #1
surge s14
surge s14's Avatar
surge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymore
heater problem HELP!
yeah my a/c blasts but my heater dosnt get hot at all anyone know why?
surge s14 is offline   Reply With Quote
Old 01-17-2007, 04:24 PM   #2
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Hard to say, dirty or maybe clogged. Would have to remove the dash and dig the heater core out to say for sure but that's a royal p.i.t.a.
Old 01-17-2007, 04:49 PM   #3
D1GP
D1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the rough
what is your temp gauge reading? is the motor getting warm at all? things you may want to look at before tearing the dash out is thermostat, radiator cap, and coolant overflow (make sure it is not cracked).
also check the hoses that run to the heater core and make sure both of them are warm to the touch (located on passenger side firewall).
i had a similar problem where my motor would not get warm and would require much punishing before it hit the half way mark. if i let it idle for a bit, it would fall back down to 1/3 of the gauge and blow cool air. i flushed the coolant, replaced the thermostat, and replaced my cracked overflow. heat gets warm now but still not as hot as i would like it to be but it is better then no heat for the winter. i will probably funk with the heater core come spring.
D1GP is offline   Reply With Quote
Old 01-17-2007, 05:49 PM   #4
benjiholt
benjiholt is an unknown quantity at this point
Just my 2 cents but you sure the heater valve is opening? Don't know if that will be the problem but it's worth checking
benjiholt is offline   Reply With Quote
Old 01-18-2007, 02:44 AM   #5
surge s14
surge s14's Avatar
where might that be?
Old 01-18-2007, 02:50 AM   #6
surge s14
surge s14's Avatar
it reads 1/2 way
Old 01-18-2007, 10:50 AM   #7
D1GP
Originally Posted by surge s14
it reads 1/2 way
ok then. check the hoses that run to the core. if only one is cold, then a valve is stuck.
Old 01-18-2007, 05:37 PM   #8
benjiholt
hey it's just behind the intake manifold on the passenger side right at the firewall i think it's a 3/4 heater hose there will be a little valve in the hose that lets the hot water get into the heater core. There is also a small wire on the valve that actually pulls it open so cgeck and make sure that it's hooked up also.
Old 01-18-2007, 07:05 PM   #9
ispypsi
ispypsi is on a distinguished road
Send a message via AIM to ispypsi Send a message via Yahoo to ispypsi
later model s14's the valve isnt on the hose, its built into the core. but you can see where the valve used to be as there is still a plastic fitting on there.
either the valve is stuck or the motor for it crapped out. this is the motor that simply opens and closes it when you slide the air mix on the hvac controls (the blue to red slide)
97 240sx ka-t. 12.8 @ 108mph. for sale $8K in Florida.
08 mazdaspeed 3. faster + quieter = sleeper.
ispypsi is offline   Reply With Quote
Old 01-21-2007, 11:17 AM   #10
benjiholt
mines a 95 S14 and the valve is in the hose I saw yours was a95 so I guess yours should be in there also but hey I coul be wrong
Old 01-21-2007, 05:59 PM   #11
g6civcx
g6civcx's Avatar
Orginal poster, please answer the following questions for more specific answers?
1) Year/make/model
2) After driving for a while, open the hood. Are the radiator hoses warm to the touch?
3) Do you detect a sweet smell inside or outside the car near the firewall area?
4) Did you bleed your coolant system properly, including the heater core?
Assuming the engine is running properly and there is no leak, the most common causes of cold heater are as follows:
a) Air pockets trapped in the heater core. You need to let the car run and slowly loosen the upper heater hose and bubbles will gush out, indicating that air is purging. Also bleed the bolt on the upper radiator hose outlet on the engine.
b) Clogged heater core. If this is the case, the only way to know is to open up the dash and remove the defective core. Then replace with a new core. This usually happens when you don't use distiled water. Tap water and old coolant rust out the inside of the heater core.
c) Broken aircock valve. This is located on the heater core itself in 240s.
