Old 01-21-2007, 02:09 PM   #1
rongfk
rongfk's Avatar
rongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond repute
Question about jdm mirrors.
ok, i have a standard s13 hatch (no power mirrors/windows). i have jdm mirrors. i did all the nessacery changes to them (swap mirrors and triangular baces) and ran the wireing to my center councle (all 5), now i dont see any extra power wires for a mirror switch. so, i spliced into my cigaret lighter. my question is will that be a problem?
thanks, ron.
p.s. i did search, and this was not mentioned.
rongfk is offline   Reply With Quote
Old 01-21-2007, 02:11 PM   #2
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
do they work? if so.. it shouldnt be a problem.. i use my cig lighter for a few power sources.
s13silady is offline   Reply With Quote
Old 01-21-2007, 02:11 PM   #3
ThatGuy
Admin Asshole
ThatGuy's Avatar
Your car will explode next time you drive over 88 mph. Either that or your Flux Capacitor will kick in, transporting you to 1985.
Should be fine, but know that the cigarette lighter only recieves 12V when the ignition is on. Therefore, you won't be able to fold or adjust your mirrors with the car off.
Old 01-21-2007, 02:13 PM   #4
rongfk
rongfk's Avatar
yea, i tested them out before takeing them apart.
Old 01-21-2007, 02:49 PM   #5
g6civcx
g6civcx's Avatar
That's fine. Just keep in mind that your lighter circuit has a 15A fuse. If all of your accessories pull more than that at any one time you'll pop the fuse.
And don't even think of using a higher-rated fuse because that's a good way of overheating the wire.
