Old 01-22-2007, 11:22 AM   #1
Jmunkee
Jmunkee is an unknown quantity at this point
s13 speedo issue
Hey dudes.
I have a problem with my speedometer. Ok so it's a 1991 1980sx with no mods other than a manual turbo timer and the speedo is doing strange things. Basically it will work for the first 5-10 minutes of driving and then it'll drop to 0 and flutter all over the place after that. Sometimes it will start working again for no apparent reason. Is it just a loose connection somewhere?
Any of you guys have any thoughts?
Jmunkee is offline   Reply With Quote
Old 01-22-2007, 11:44 AM   #2
Dream240
Dream240's Avatar
hey dude....
Get under your car and check the connector for the speedo. It's the last plug at the back of your tranny. Might be a bad sensor. Also check your fuses.
Old 01-22-2007, 11:45 AM   #3
los_inc
los_inc's Avatar
los_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond repute
Send a message via AIM to los_inc
check your cluster wiring and sub harness and or your speed sensor
keep it mind it's an 18 year old car
los_inc is offline   Reply With Quote
Old 01-22-2007, 02:06 PM   #4
g6civcx
g6civcx's Avatar
Speedometer failure is common on S13s. Check all connections, and if nothing is found, replace the speedometer display. Any year S13 speedometer will swap in.
Old 01-22-2007, 02:44 PM   #5
Dream240
Dream240's Avatar
2007 - 1991 = 16
you win...
Old 01-22-2007, 03:00 PM   #6
g6civcx
g6civcx's Avatar
Originally Posted by Dream240
2007 - 1991 = 16
you win...
Keep in mind that model year cars were usually built some time in the previous calendar year. So a 1991 model could have been built some time in the summer or fall of 1990. On top of that, the actual parts could have actually been built quite some time before final assembly.
Old 01-22-2007, 03:13 PM   #7
Dream240
Dream240's Avatar
ummmm...nah. Still don't add up.
You could just as easily go the other way with it. Car made mid 1991, actually sold end of year....so parts are really only used since 1992.... 15 years.
We both win....
Old 01-22-2007, 03:59 PM   #8
g6civcx
g6civcx's Avatar
We both win....
Don't forget sales people and dock workers joyriding.
Old 01-22-2007, 04:06 PM   #9
Jmunkee
Thanks guys. Seeing as how it will work the connection or sensor being loose or faulty sounds like it might be the problem. I'll check that and the fuses.
Old 01-23-2007, 11:11 AM   #10
Clawhammer
Clawhammer is making a name for him/her selfClawhammer is making a name for him/her self
Send a message via AIM to Clawhammer
Is it like this:
http://www.zilvia.net/f/showthread.p...meter+question
Clawhammer is offline   Reply With Quote
Old 01-23-2007, 06:25 PM   #11
Jmunkee
Yah it's exactly like that.
Did you try those things? Did you fix it?
Old 01-23-2007, 06:35 PM   #12
slideshow240
slideshow240 is a well-known jackass
Send a message via AIM to slideshow240
check ground wires...mine did the same thing
slideshow240 is offline   Reply With Quote
