Old 01-29-2007, 05:17 PM   #1
JDMClifford
JDMClifford's Avatar
JDMClifford is an unknown quantity at this point
SR20det red top will not start
Installed new stock cams. Set timing right. Intake cam set at 10 o'clock, exhaust set at 12. Has spark and fuel, but will not fire. Checked grounds and plugs and everything is good. Completely stumped. Anyone have any ideas??
Parking lot pimping
JDMClifford is offline   Reply With Quote
Old 01-29-2007, 05:35 PM   #2
GSXRJJordan
GSXRJJordan's Avatar
So you've got spark at the plug? That rules out ECU power issues and igniter... I'd say Cam Angle sensor (you pulled it right, maybe put it in 180* off?) or MAFS, maybe TPS or some other electronic reason for too much fuel? What about IACV?
If by "set timing right" you mean mech timing to FSM those are about all I can think of... I've never had spark and fuel and not gotten da bitch to turn over... does it sound like it wants to start, like chugging, or anything?
Old 01-29-2007, 05:43 PM   #3
JDMClifford
Starter turns engine over, but it just won't fire. Checked each spark plug while attached to the coil and they all produced a healthy spark. Car has fuel pressure and I could smell fuel on each spark plug when they were pulled.
Parking lot pimping
Old 01-29-2007, 06:06 PM   #4
JDMClifford
Pulled cam angle sensor and checked it. Not turned 180 degrees so it's not that.
Parking lot pimping
Old 01-29-2007, 06:17 PM   #5
Markovich
Markovich's Avatar
Markovich is an unknown quantity at this point
compression?if you did what i did you will need to take both the cams off again and bleed the lifters if you let them sitt uncompressed you will have no comprsseion if you want be very carefully and loosen all the cam bolts and check compression i bet it would start then
peace
7-mount sr20det evo3 16g in a 90 240sx coupe
yes its a nisclipse bitch
Markovich is offline   Reply With Quote
Old 01-29-2007, 06:29 PM   #6
JDMClifford
lifters? what do you mean? lash adjusters?
Parking lot pimping
Old 01-29-2007, 06:35 PM   #7
Markovich
Markovich's Avatar
the hydralic lfters they sit in the head and ride on the rocker arm so when the cam turns it pushes down the lifter instead of the valves.
Old 01-29-2007, 06:35 PM   #8
nka203
nka203 is on a distinguished road
i think its a timing issue, mess around with the distributor, i had a very similar problem, with good fuel and spark but no start. i pulled out the distributor, put it back in bout 3 degrees to the left and it fired right up. i'm probably wrong im a noob at this stuff but just my opinion.
nka203 is offline   Reply With Quote
Old 01-29-2007, 07:52 PM   #9
j20accord00
j20accord00's Avatar
j20accord00 is an unknown quantity at this point
Send a message via AIM to j20accord00
hey I got a quick question for you, I a little off topic but none the less, I bought JWT C1 cams and when I got them on my exhaust cam where the CAS goes on to there is a like a little peg if you will that is on there and it then slides up the CAS thread thing...My friend said I had to take that off of my stock exhaust cam and swap it with the new one because C1 cams are used for Sr20 rear and front wheel drive cars. so I was just wondering if you had to do that or not? or if anyone has? I cant seem to get it off without messing it all up? I hope you get waht I mean if not Ill take a pic of it. thanks alot, Evan
j20accord00 is offline   Reply With Quote
Old 01-29-2007, 08:05 PM   #10
JDMClifford
sr20dets have cas not a distributor. and bles lash adjusters no go... maby i am setting the timing chain wrong. i jsut set the motor to tdc whitch is the first mark on the far left on the crank pulley. then put the cams 10 and 12 o'clock, next alight the cas. i did all of that like 3 times and i still cant get it to work.
Parking lot pimping
Old 01-30-2007, 06:05 AM   #11
Markovich
Markovich's Avatar
how did you keep the lifters when you had the cams out?
if you didnt touch them then walla theres ther problem just bleed them. place in a cup of oil holding them straight up and push down the check valve through the little hole in the top make sure it doesnt suck air in
peace
Old 01-30-2007, 07:29 AM   #12
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
make sure your fuel lines arent backwards. when i put my SR in, i had them backwards and the engine was getting a little tiny bit of fuel, but not enough to start. its just something to look at.
ladiesman8527 is offline   Reply With Quote
Old 01-30-2007, 11:15 AM   #13
Markovich
Markovich's Avatar
Sigh! kjjouhgyiogigpugh[oijh'
Old 01-30-2007, 01:34 PM   #14
GSXRJJordan
Yeah JDMClifford, I didnt think about the fact that in pulling your cams, you have to bleed the lifters, because if the cam was pressing down on one (which it is, no matter what position it was in when you pulled it) and you relieve that pressure, air gets sucked in... anyway, you can check for compression first if you want, just hook up a compression gauge and turn the engine over by hand and see if you're remotely close (if there's a problem with lifters/compression, your readings will be somewhere around 20-50, instead of >120). Here's some info from jgycustoms.com:
Does your SR20 have a "TAP-A-TAP-A-TAP-A-TAP" noise? The most likely suspect is air in the lifters. If you look at my finger location in the picture, I'm pushing down on the back of the rocker arm on the section that rides above the lifter. While pressing, if you feel any movement, you have air in that specific lifter. SR20 lifters are hydraulic but can not bleed themselves like most hydraulic lifters. To bleed your lifters you must remove your valve cover, the cams, and rocker arms. Pull the lifter out of its sleeve making note not to tilt it sideways, submerse it in oil, and insert a thin piece of rigid metal inside the hole on top of the lifter. Keep in mind, entire lifter must be completely submersed in oil. You will feel a groove with your metal probe, if you press down it will compress the internal mechanism. Do this repeatedly, many times, or until it doesn't depress anymore. Carefully insert it back into the sleeve without tipping it so that air does not enter it. Reinstall the rocker arms, cams, and valve cover and listen to see if the noise persists.
Old 01-30-2007, 02:44 PM   #15
JDMClifford
fuel lines are not backwards haha, ok im gona bleed all the lifters this time. i was also thinking maby i am bot setting the cams at 10 and 12 when the tdc is on the compression stroke. would it matter?
Parking lot pimping
Old 01-30-2007, 02:50 PM   #16
Markovich
Markovich's Avatar
yes check compression first which i said back on post #5 now on 16 we got somewhere....
peace
Old 01-30-2007, 02:55 PM   #17
JDMClifford
ya im gona im jsut waiting for a friend to bring over his compression tester.
Parking lot pimping
Old 01-30-2007, 03:00 PM   #18
Markovich
Markovich's Avatar
sweet!! hope it works i hate to see s bodys sitting
peace
Old 01-30-2007, 06:18 PM   #19
JDMClifford
ok i got it to start. but its flooding. after i crank it with no injectors pluged it then run it when it has injecters it will only start if i floor it and start it. it also has verry bad throttle responce. and will notidle by its self.
Parking lot pimping
Old 01-30-2007, 06:29 PM   #20
GSXRJJordan
Now we're gettin somewhere ~ what did it? Did you end up compression testing it? That sounds like your compression might still be messed up.
Now I'd start checking TPS, MAFS, IACV, vac line to FPR, there's a couple other things that can make it run badly.
Old 01-30-2007, 07:19 PM   #21
bongnak
bongnak's Avatar
bongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of light
did you take out your injectors by any chance? if so check the o rings. went thru the same thing a while back
Zzzz
bongnak is offline   Reply With Quote
Old 01-30-2007, 10:33 PM   #22
JDMClifford
i didnt take them out after it fan fine. now it runs like ass.
Parking lot pimping
Old 01-30-2007, 10:47 PM   #23
JDMClifford
all vac lines are good maf is good tps is good dont know acout compression and iacv.
Parking lot pimping
Old 01-31-2007, 12:01 AM   #24
JDMClifford
you can swap the cam gears. i have a stock exhaust cam gear if you need one or you can buy adjustable ones.
Parking lot pimping
Old 01-31-2007, 07:40 AM   #25
JDMClifford
ok so i couldnt sleep, so i was up at 4 in the mothing and i bled the lifters. agan... havent started my car and am goind to check the compression when my friend gets off work at 3. i was also thinking could it be the headgasket? maby i need oil on top of the pistons because it has 10 mins on the freshly rebuilt motor? i know for sure its not electrical it has to be something with the head.
Parking lot pimping
Old 01-31-2007, 10:26 AM   #26
S14DB
AFC #1
S14DB's Avatar
#1 cyl at TDC the Intake cam should be a 9 o clock and the exhaust at 3 from the front of the engine. Basically straight out.
Old 01-31-2007, 11:35 AM   #27
Markovich
Markovich's Avatar
so bleeding them worked? what was your numbers just by chance before and after? WAIT rebuilt motor? how did you run it? did you run it for an hour and then turn off and drain oil and put new oil in?
peace
Old 01-31-2007, 11:41 AM   #28
steve shadows
steve shadows's Avatar
Make sure you turn your engine manually with a 27mm socket with the Valve Cover removed until the Shiny or Mis-Colored Links line up dead on the Cam Sprocket Dots on the Cams. Then drop a screw driver (a long one) softly into the No. 1 Cylinder to check the piston hieght in the stroke. Also the little notches on the crank shaft - The 2nd one from the intake side should be aligned with the pointy ice pick thing jetting off the front of the timing cover. That marks TDC as well..
then...
do this.
Like Me on FaceBook !
Old 01-31-2007, 03:06 PM   #29
JDMClifford
i havent ben able to run the motor for more than 10 mins, first it was ticking really bad because i didnt have a valve shim on one of the valves now it wont start.
peace
and WHAT! no its supose to be at 10 and 12.
Parking lot pimping
Old 01-31-2007, 03:07 PM   #30
steve shadows
Wow
Time to pull the head or at least pull cams and re-shim the head.
