Old 02-02-2007, 10:34 AM   #1
240blitz
240blitz's Avatar
240blitz is an unknown quantity at this point
spark plug question
i'm building a high comp ka24de and am trying to find out what heat range spark plugs i should get. hotter or colder?
240blitz is offline   Reply With Quote
Old 02-02-2007, 11:34 AM   #2
pr0ject TRUENO
pr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfection
Send a message via AIM to pr0ject TRUENO
general rule of thumb is whenever you run a higher power output than stock it increases combustion chamber temps, so you'd run a cooler plug.
pr0ject TRUENO is offline   Reply With Quote
Old 02-02-2007, 06:45 PM   #3
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
yea run a colder plug man if you are looking to run a different range, try about 3 colder and see how that works out, also try searching what others are running for similar setups
Slip Gypsies Blog
not sure if you realize this
Old 02-06-2007, 10:02 AM   #4
oneleg180
oneleg180 is an unknown quantity at this point
Send a message via AIM to oneleg180
Are you suggesting that he run plugs with a heat range of 8? Whatever you do, be sure to use ONLY NGK.
oneleg180 is offline   Reply With Quote
Old 02-06-2007, 10:26 AM   #5
MadScientist
MadScientist's Avatar
MadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really nice
Actually you will be perfectly fine running 7.
7s are mostly used for Turbo and High Comp vehicles.
If you are going to push over 400hp with a Turbo or SuperCharger then you would go with 8+.
Peace
Drew
Follow on IG - KoukiTheToolBox
MadScientist is offline   Reply With Quote
Old 02-06-2007, 02:30 PM   #6
CleanKAKouki
CleanKAKouki's Avatar
CleanKAKouki is making a name for him/her selfCleanKAKouki is making a name for him/her selfCleanKAKouki is making a name for him/her self
i agree, whatever you do, pleae use NGK. i made the mistake of running the cheap napa autolites....never again. NGK is the where its at for imports
CleanKAKouki is offline   Reply With Quote
Old 02-06-2007, 02:45 PM   #7
teamsprock
teamsprock's Avatar
teamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the rough
I would start with one heat range colder and see if you have signs of detonation. Colder plugs won't perform as well and will foul quicker if they are too cold. You really only need to go colder to avoid detonation.
teamsprock is offline   Reply With Quote
