Old 02-02-2007, 09:58 PM   #1
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
Rebuilding my pass. axle.... HELP!!!
I have a track day in 12 hours and counting down..so PLEASE bear with me and help!!
I have a bad passenger side axle on the car. I have a set of spare axles laying around, but the spare passenger side axle has a bad outer(go figure).
SO, I took the spare DRIVERS AXLE, and took the OUTER bearings/spline off of it and put it on the spare PASSENGER axle to replace the bad part. Everything came apart and went together with just one c-clip and everything went smoothly...
HOWEVER, now that i'm all done, i notice both passenger side axle OUTERS(part with the spline...the part i replaced along with the bearings) has a letter Z on them. The drivers side i took has a C on it. Is there a difference or was it just a factory marking and a coincidince that both passenger sides had the same Z on them?
PLEASE HELP!!! Track day tomorrow with a two hour drice each way.....
gotta240 is offline   Reply With Quote
Old 02-02-2007, 11:36 PM   #2
UNITEDMASTER
UNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to all
Hello ,it should fit,but its not good IMO to mix & match inners/outers & shafts. But it should work out. PEACE
MR JACKSON.
UNITEDMASTER is offline   Reply With Quote
Old 02-02-2007, 11:56 PM   #3
gotta240
cool, thanks... So far so good!!!
any other opinions on this hybrid shaft?
