Old 02-03-2007, 11:48 PM   #1
Skullavera
Skullavera's Avatar
Skullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfection
Send a message via AIM to Skullavera
S14 Auto problems under heavy acceleration. Cant figure it out!
Hey everyone, I'm having trouble with my S14 "bogging out" under heavy acceleration. The problem doesn't happen all the time but every once in a while it will. It can get to the point where I have to barely give it throttle so that it doesn't bog out. It feels as though it may be the TPS but does anyone else have any other suggestions? The engine has 156XXX miles and has been well maintained. This just started happening about a week an a half ago too. The car is an automatic. I have also searched but unless I search for keywords in the actual thread title (which only turns up about six threads under Tech Talk), I get a blank page!
Reviews/Feedback!
Skullavera is offline   Reply With Quote
Old 02-04-2007, 12:31 AM   #2
Gnnr
Gnnr's Avatar
Any engine codes? Maybe fuel filter?
Gnnr is offline   Reply With Quote
Old 02-04-2007, 02:33 AM   #3
Taniguchi_Is_#1
^^ sounds like fuel filter.
Taniguchi_Is_#1 is offline   Reply With Quote
Old 02-04-2007, 11:41 AM   #4
Skullavera
Skullavera's Avatar
Ah....I will change that today and see if that was it. Might as well pick up a 300zx one since I have to get one! I will keep you posted. Thanks!
Jose
Reviews/Feedback!
Old 02-04-2007, 11:48 AM   #5
'90RPS13
'90RPS13's Avatar
'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute
Send a message via AIM to '90RPS13
Lemme know what you find out. I am having the same problem in my Auto S13 KA. *a
'90RPS13 is offline   Reply With Quote
Old 02-04-2007, 02:50 PM   #6
'90RPS13
'90RPS13's Avatar
*Edit*
Its the fuel filter. I just changed mine out. Ran all the air bubbles out and runs fine now. Took the old filter off and rusted nasty ass gas came out. So, new filter at napa is like $10.49. *A
Old 02-07-2007, 09:04 AM   #7
'90RPS13
'90RPS13's Avatar
Well the problem is back but not as bad. It only dies at low speed. Once I get into 3rd gear, its fine, I can mat it and everything is there. Fuel Pump?
*a
Old 02-07-2007, 10:09 AM   #8
Dream240
Dream240's Avatar
Get a fuel pressure test first. I could be the pump, an injector, bad o-ring, faulty TPS, the list goes on. Fuel pressure test will rule out the pump. Then test the TPS for voltage. Those are good then check your injectors.
Old 02-14-2007, 01:44 AM   #9
Skullavera
Skullavera's Avatar
Yeah I have to do that because it seems as though it only does it under heavy load now. Filter did help out but the problem came back, as with '90Silvia. Thanks for the help guys and I'll keep you posted...
Reviews/Feedback!
