Old 02-22-2007, 03:43 PM   #1
kenversusryu
kenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nice
Kill switch need relay?
I have done the search and I couldnt' find the answer to my question for our car.
I'm going to setup a fuel pump killswitch by splicing into the fuel pump. I'm going to set up the wires up to the dashboard. BUT I've read that if you're using too much wire, you might need a relay. Again I'm going to use enough 14 gauge wire to go from the rear(pump) to the dash. I will also solder, shrinkwrap, and use a radio shack 20 or 30 amp switch.
Please tell me if a relay is necessary. I got the info from a honda board.
kenversusryu is offline   Reply With Quote
Old 02-22-2007, 03:50 PM   #2
projectRDM
projectRDM's Avatar
You didn't search. Do not lie to us.
Intercept the fuel pump signal wire, black/pink, it's a low current ground. No need for a relay.
Old 02-22-2007, 03:50 PM   #3
'90RPS13
'90RPS13's Avatar
'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute
Send a message via AIM to '90RPS13
You dont need a relay. Just tap in and be done with it. You would only need a relay for the Cig lighter Push Start/Kill Switch Idea. *a
*Edit*
Russ Wins. Haha, he beat me by MERE SECONDS I tell ya. Haha.
'90RPS13 is offline   Reply With Quote
Old 02-22-2007, 04:40 PM   #4
kenversusryu
I guess I"m bad with searching then. BTW search function works perfectly fine for me. I dunno why everybody else have problems. I guess the search button likes macs.
Thanks for the replies guys!
