Old 03-02-2007, 07:19 AM   #1
jim1234664
jim1234664's Avatar
jim1234664 is an unknown quantity at this point
switching to synthetic on a 75k mile 91 KA
im planning on turboing my KA this summer and my friend with a 1.8t passat says that at least for his car, synthetic oil is a must. ( becuase of the turbo)
the question is: does this same concern exist for the ka ( with a turbonetics turbo from the jgs kit) and how bad will it / could it be for the motor? (as far as blow by on piston rings and other seals)
jim1234664 is offline   Reply With Quote
Old 03-02-2007, 07:28 AM   #2
Duzzes_Wild
Duzzes_Wild can only hope to improve
if you have concerns that your engine will produce blow by from synthetic oil alone then you probably shouldnt be turboing without a rebuild. syn oil as alot thinner than conventional motor oil, i bet with turbo and syn you'll have some blow by. to anwser your question syn oil isnt bad for your piston rings or for anything else for that matter. just try it if you see blow by run it till and blows and build one ka's are cheap man
Duzzes_Wild is offline   Reply With Quote
Old 03-02-2007, 08:35 AM   #3
jim1234664
jim1234664's Avatar
the thing is i have a 75k mile ka and if i could get at least one season out of it id be happy, i dont really have the money to turbo and rebuild it at the same time.
if i switched to synthetic and had a lot of blow by would any permanent damage be done?
would i be able to switch back to dino oil w/o problems?
moreover is synthetic required for a turbo setup?
Old 03-02-2007, 10:57 AM   #4
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
Do NOT switch to synthetic on a high mile engine. Just... Don't... Do it.
-Kyle
