Old 03-02-2007, 12:09 PM   #1
shift_drift
shift_drift is an unknown quantity at this point
strange wot problem
Car is a 92 coupe with a ka.
Whenever I do a wot pull, the car will rev perfect through 1st and second, but in third, it feels like i'm hitting fuel cut at about 5500rpms; the car just bogs like crazy. It does this almost everytime. Then, sometimes it'll do similar things in other gears, but in the other gears, if I keep it at wot, the car will "bounce" off the "limiter" at a much lower rpm, then all of a sudden sort itself out and take's off like crazy. The thing about this that throws me off is that it doesnt happen all the time, usually the car runs fine other than the 3rd gear problem, but if i run into the 3rd gear problem, it will start doing the same thing in the other gears, but at lower rpms.
hopefully what i've typed makes sense....anybody have any ideas?
shift_drift is offline   Reply With Quote
Old 03-02-2007, 12:15 PM   #2
'90RPS13
'90RPS13's Avatar
'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute
Send a message via AIM to '90RPS13
Same problem in my '91 KA.
'90RPS13 is offline   Reply With Quote
Old 03-02-2007, 12:32 PM   #3
shift_drift
took the car out today, and when I did a wot pull in 2nd, and when after when I switched to third and hit the gas again nothing happened, at wot the rpms wouldn't move. when I let off the car died, and I let it sit for a minute, started it up and it ran fine again. this shit is crazy.
Old 03-02-2007, 12:36 PM   #4
Sidewayzzz
Sidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura about
Send a message via AIM to Sidewayzzz
Swirl Control Valve can be sticking, it opens and closes secondary butterflies in your intake manifold, take a look at the diagnostic procedures in the FSM.
Sidewayzzz is offline   Reply With Quote
Old 03-02-2007, 12:36 PM   #5
s13gold
s13gold's Avatar
Trader Rating: (79)
s13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfection
Feedback Score: 79 reviews
distributor.
s13gold is offline   Reply With Quote
Old 03-02-2007, 12:40 PM   #6
arkive43
arkive43's Avatar
arkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud of
hmm what have u checked? could be a fuel or mabey ur maf acting up....mine did that (i have a 91 coupe) cleaned my maf, changed to a z32 fuel filter and it seemed to go away...//it would bog in 3rd//
arkive43 is offline   Reply With Quote
Old 03-02-2007, 12:47 PM   #7
shift_drift
I did a power balance test, cleaned my maf, the egr is working fine, couldnt find any vacuum leaks. I'm about to go check my plugs/wires/dist cap&rotor, but all of those are less than a year old and have less than 7k miles on them. I'm going to replace the fuel filter today, and the plugs if they look messed up. Is there anyway to check the distributor or coil other than switching it out with a known working one?
Old 03-02-2007, 02:08 PM   #8
Dream240
Dream240's Avatar
Per the FSM, in section "EC" page EF & EC 86:
DIAGNOSTIC PROCEDURE 17 - LACK OF POWER AND STUMBLE
CHECK FUEL PRESSURE: IGN ON - 43 PSI, AT IDLE - 34 PSI
CHECK INTAKE AIR LEAK, lower blow-by air supply, does engine speed rise?
Download an FSM and check out section EC. Best section.
Old 03-02-2007, 02:47 PM   #9
shift_drift
I've been messing with it for a while now. I need to go by a fuel pressure guage now. Thanks for the advice.
