Old 03-02-2007, 01:02 PM   #1
nissandr1ft
nissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura about
Send a message via AIM to nissandr1ft
Crankshaft Position Sensor code?
Well I decided to check for codes the other day since I havent since Ive had the motor in the car for the past 2 monthes. I expected a code 55, but in turn got a code for the crank position sensor. Ive had this problem before with my previous motor. The harness came from a good running car, the ECU came from a junkyard with a Nissan sticker stating it was remanufactored in 2004. Ive tried 2 different distributors, and both end up throwing the same code. Is there anything else I should try, or should I just try to find another distributer to try?
Steven
www.carolinanissans.com
nissandr1ft is offline   Reply With Quote
Old 03-02-2007, 01:30 PM   #2
S14DB
AFC #1
S14DB's Avatar
S13 or S14? Which code(GST/ECM)?
Old 03-02-2007, 02:33 PM   #3
projectRDM
projectRDM's Avatar
Why would you swap distributors if the crank position sensor is throwing a code? That's like putting on a new tire because your trunk won't latch. Two completely unrelated things.
Old 03-02-2007, 03:19 PM   #4
cotbu
cotbu's Avatar
code 11 or code 82 or code 95
Try stating the exact code...!
Old 03-24-2007, 03:18 PM   #5
Lith
Lith will become famous soon enoughLith will become famous soon enoughLith will become famous soon enoughLith will become famous soon enoughLith will become famous soon enough
Send a message via ICQ to Lith Send a message via AIM to Lith Send a message via MSN to Lith Send a message via Yahoo to Lith
Crankshaft Position Sensor is code 82
Lith is offline   Reply With Quote
Old 03-24-2007, 04:13 PM   #6
drftwerks
cam pos sensor is in the dizzy not crank
giantroboteyes.wordpress.com/
Old 03-24-2007, 11:03 PM   #7
scruffy63
scruffy63 has a little shameless behavior in the past
Send a message via AIM to scruffy63 Send a message via Yahoo to scruffy63
this is true for the ka24e not the de
How to tell if you're a drifter:
1. You don't care if you're doing 60+mph through any turn at any given time
2. You're horribly afraid of speed Bumps.
3. You take your right turns turning left.
scruffy63 is offline   Reply With Quote
Old 03-24-2007, 11:35 PM   #8
projectRDM
projectRDM's Avatar
You fail at the internet.
The camshaft position sensor is located in the distributor for all models, E and DE.
The crankshaft position sensor, an S14 only item, is located on top of the bellhousing.
Again, two completely different, unrelated items. The CMPS controls ignition timing, the CPS is simply a diagnostic sensor that monitors misfire. It can be removed and thrown away with no ill effect.
