Old 03-04-2007, 01:41 PM   #1
jmizell2
jmizell2 is an unknown quantity at this point
KA Conzult wiring for pre OBD2
Can anyone tell me the correct wires to hook up a conzult connector to a pre obd2 harness (1993)
I am having a spark issue and need to moniter sparks advance a fuel injection while running.
jmizell
240sx 1990 s13 with a 1998 s14 DOHC swap that I autocross.
jmizell2 is offline   Reply With Quote
Old 03-04-2007, 02:11 PM   #2
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
http://www.plmsdevelopments.com/consult_wiring.htm
driftingisgay.com
nrg is offline   Reply With Quote
Old 03-04-2007, 05:07 PM   #3
g6civcx
g6civcx's Avatar
Check under the underdash fusebox for the CONSULT connector.
Old 03-04-2007, 05:46 PM   #4
projectRDM
projectRDM's Avatar
All 91-up cars have a CONSULT plug.
Old 03-04-2007, 09:43 PM   #5
jmizell2
conzult plug
I need to restate my configuration. I have a 1990 nissan 240sx with a 98 engine. I used a 93 engine harness plus ecu and distributor to make it all work together. I do not have a conzult plug but think that one can be wired into the harness if I knew which wires to access.
Thanks for all the replies so far.
John
jmizell
Old 03-05-2007, 12:05 AM   #6
projectRDM
projectRDM's Avatar
FSM.
There's a total of five wires, three from the ECU, ground, and ignition. Very, very simple.
Old 03-05-2007, 06:37 PM   #7
jmizell2
does it require a special cable to access the ecu.
jmizell
Old 03-05-2007, 06:48 PM   #8
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
IN order to read from the consult port, you will need some sort of cable and a device (N Probe/Conzult/CalumSult) to read it...
When I swapped my Redtop in my 97, the consult wasn't wired into the conversion harness...I actually wired the port in it direct, and put the connector on the passenger side, as I knew it would make it easier than having to tangle the cord all over the driver when reading from it
