Old 08-18-2002, 06:18 PM   #1
anisht
anisht is an unknown quantity at this point
Im thinking of getting some iridium spark plugs (densos) and im not sure how exactly.  My understading, is the spark plugs connect to the wires, so i follow the wires to the engine, and thats where the plugs are, right?  Do they screw out?  Ive been looking for a how to somewhere on the internet, no luck.  Any advice, appreciated.
Thanks guys!
Cheers!
anisht is offline   Reply With Quote
Old 08-18-2002, 06:32 PM   #2
gh6o6
gh6o6 is an unknown quantity at this point
this is one of the simpler thing to do, and in all seriousness if you dont feel comfortable with this dont do it. other than that heres the directions:
depending on what engine you have, the plugs are in different places.
on a dohc there right on top
on a sohc there on the side
follow the wires down from the distributer and find the plugs
doing only one plug at a time (thats important because you dont want to mix up wires) pull the wire straight out of the hole.
get a socket wrench, extention, and a spark plug socket
connect them all together and take out a plug and replace with the new one - just snug it! that means about a .5 turn after it stops!
put the wire back in and snap it back in
go on to the next one and when your done go for a ride
gh6o6 is offline   Reply With Quote
Old 08-18-2002, 07:56 PM   #3
Frappe
Frappe's Avatar
Frappe is an unknown quantity at this point
Send a message via AIM to Frappe Send a message via Yahoo to Frappe
Also, slight addendum, make sure to get a spark plug socket with the rubber grabber thingy....at least for the DOHC, I think it's the same for the SOHC. And it's recommended to use silicone lubricant or something on the plug threads when you put them in...to prevent sticking, I think. Please correct me on that second part if I'm wrong, I'm not as sure about that.
-Frappe
(sold) '96 S14b
Zenki4ever
Frappe is offline   Reply With Quote
Old 08-18-2002, 08:04 PM   #4
phatsx
phatsx's Avatar
phatsx is an unknown quantity at this point
make sure the engine is not hot.  If it is, the grommet is the socket can melt to the plug.
Nsport turbo kit, JWT ecu, JWT fuel rail, MSD 72lb injectors, Cobra MAF,SPEC clutch, KYB agx shocks, Eibach Pro springs,Apexi GT Spec exhaust, 18x8 Konig flight wheels, BFG KDW 265/35/18 (rear) Dunlop fm901 225/40/18 (front), indash tv and dvd player with ps2 and some more stuff that I probally can't remember
1/4 Mile:13.9 @ 105 / 7lbs of boost w/o JWT mods
http://www.eframes.com/default.asp?g...bum=38203.2910
phatsx is offline   Reply With Quote
Old 08-18-2002, 08:16 PM   #5
anisht
I hear i need to gap the plugs, or something?  What exactly is involved with that?
Old 08-18-2002, 08:47 PM   #6
gh6o6
most newer plugs come gapped
i know you should never gap a platnum plug
im not sure about iridium
get a measuring tool and measure them if you feel so inclined
my car has the boch platnum +4 plugs that are ready to be installed right from the box.  a couple of other people have then too.  personally i didnt notice a diference from the stockers, but they were due to be changed
Old 08-18-2002, 11:01 PM   #7
sileighty
sileighty is an unknown quantity at this point
never gap platinum plugs? why not? you mean bosch ones?
bosch sux
long live ngk r
sileighty is offline   Reply With Quote
Old 08-19-2002, 02:28 PM   #8
anisht
ill be getting denso iridium plugs...
Old 08-20-2002, 07:44 AM   #9
phatsx
phatsx's Avatar
Since you are getting iridium plugs, you wont have to worry about gapping them. when you see the tip you will know why they come gapped from the factory. Also NGK has a new iridium plug out now too.
