Max MPH
This post is not about TOP END MPH. I am interest in mph in each gear.
This is the info I found out 1st gear = 3.321 2nd gear = 1.902 3rd gear = 1.308 4th gear = 1.0 5th gear = .759 rear gear =4.083 Ok using the varios calculators, I came up with the following: with stock wheels size 195R 15s = 24.2 in dia. so with 6k RPM shift I would get max MPH for the following: 1st gear = 31mph 2nd gear = 56 mph 3rd gear = 81 mph 4th gear = 106mph 5th gear = 140mph I don't have a working tach. So can anyone verify this info for me? Thanks Last edited by 9DSX_DRVR; 03-28-2007 at 11:23 AM.. |
#3 | |
![]() Join Date: Mar 2002
![]() Feedback Score: 9 reviews
There are online calculators for this sort of thing if you can use google.
Out of curiosity, why the need to know? You shouldn't really be going over 75 or so on public roads. Def. not over 100, and especially not on stock tires.
![]() Join Date: Aug 2003
acording to the calculator i did 152 in my s13 automatic
this may or may not be correct accounting for windspead and resistance i was probably realisticly doing 145
Drives a BRZ and is building a V6 S12 coupe. |
if it's downhill and you have aero, you can probably go for more,
change to a vlsd from j30 which i believe has a different gear ratio that'll net higher mph, forgot, but in any case, we're not going to beat any land speed record... i can only picture the bolts on our car slowly unscrewing itself once it hits 90 mph, lol |
#8 | |
![]() Join Date: Sep 2004
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
I have an R32 vlsd. Do you have any idea on specs of this? When i do a Wangan Run....my car tops out at 145......i feel like the engine has a little bit more power......but it seems im limited....maybe my diff? possibly wind resistance? LOL at stuff unscrewing......i dont doubt it haha.
#10 | |
![]() Join Date: Aug 2005
#11 | ||
![]() Quote:
I used a calculator online. But, I wanted to verify what the "numbers" say and what you get in reality. So here is the BIGGEST reason. I want to know the max MPH in each gear. ie what is the fastest I can be going in a gear and can down shift. So If I am in 5th gear I don't want to downshift if I am going over 106mph. So I am not really interested in the top end like everyone thinks this post is about. Another reason is I don't have a working tach yet. Tachs in the SOHC cars won't work with the sr20 motor. Quote:
#12 | |
#14 |
Automatic s13's dont have a speed cut
SOHC 5 speeds cut at 115 DOHC 5 speeds cut at 120 SR SHOULD be the same but I DON'T KNOW And that is based off of stock speedo, different tires = different actual speed cut off
#15 | |
![]() Join Date: Jul 2006
BitDestroyer.com |
#16 |
Nah I had a 'danger to manifold pressure' warning light before hitting 90 I decided to back down then
#17 | |
![]() Join Date: Sep 2006
![]() Quote:
#19 |
![]() Join Date: Dec 2002
Scott Avoy ran his SR all the way out on a dyno, 5th gear redline was 172MPH. Realistically with drag and windspeed that's maybe 155-160. I've had my old car to 148MPH before, verified by the MDM-100, which receives signal directly from the VSS. Accounting for tire size that's about 145MPH.
The numbers above are good to use only if you're still running OE tire sizes, after that you can probably add another 5-10MPH on each one. I want to say my old car would do 35 in 1st, 65 in 2nd, 90 in 3rd, 115 in 4th, and 5th was whenever I let off. |
#20 | |
Its kinda hard to speed shift w/out a tach. But at least if I know the speed limit in each gear I can guess. Damn, I need to get that tach soon! |
#21 |
![]() Join Date: Feb 2004
So....here's the math:
Speed[mph] = (RPMengine)/(Gear ratio)/(Rear end ratio)*pi*(diameter of tire[in])*7.33 I don't know for sure if there is or isn't a primary reduction in the tranny or not. But if not, this will be your ground speed. Also, wind resistance is not going to change this number. The force from wind resistance will slow down your acceleration to this speed, and will limit top speed if your engine doesn't have enough power to overcome it. But if your going a set RPM in say 4th gear, do the math and that will be your vehicle speed.
#22 |
yeah im running the stock 15's. 148 sounds about right....i think ill top out around there if i get the change to drive on a longer straight.
#23 | |
![]() Join Date: May 2006
i've done 140 on mine
#24 | |
Im planning on hooking one up. HWY runs are more dangerous to your bank account and driving record and your own personal life when its 330 AM then other people typically. I have always had the personal policy of aiming for something hard and killing myself if I start to lose control than hitting some innocent person. but yeah, depends. I’m running a 4.36 final with a sr 5 speed gear box. Who knows how fast i'm going after _____ rpm in 4th gear for example. Really really fast im sure. I mean what does an E46 M3 top out at? I kind of pooped all over his investment. When I get the wheel speed sensor iir to come back on here, ill let you know haha. PS. the stock Nissan S13 SR Speed sensor is worthless after 128 mph or so as in drawing any sort of usable signal or speed reading. Not sure if the s15 is better or s14 etc. BTW I've done top speed pulls with the 3.90 LSD, the 4.10 and the 4.36. The 3.9 was definitely longer however the 4.08/10 was better overall. The 4.3 is nice and feels longer than I expected overall and is better for a car that sees lots of joshin-off and not just a specific straight line run. It all depends on what your trying to do. I think the 3.5 is way too long unless you have a custom gear set and then it would be applicable for drag (using a nice gear with an auto tranny and good stall + 200 shot etc) for lots of traction etc. Its all up to you folks im just rambling now. ![]()
Like Me on FaceBook ![]() |
#26 | ||
I meant anyone, not just 240sx. Essentially one of those 'just because you can doesn't mean you should' deals. I won't lie, I've taken my car to over 130mph, but it was a stupid immature thing to do. I put myself and others into a risky situation, and could've resulted in a grave outcome. Putting yourself in danger is one thing. I don't really care much about that - but when you jeopardize the well-being of others, you're in the wrong. That happens any time you drive recklessly on public roads. People frequently don't grasp the gravity of the responsibility of driving a car and how one error can lead to a lifetime of pain or death. So far, I've been lucky. I've been in one crash, and it's been on a closed circuit - completely my fault (overconfidence), and I never put anyone into danger that wasn't doing what I was doing. I know 240s can go fast, but it's dangerous to others to do so, and not worth the brief thrill associated with it.
#27 |
154mph before cop clocked me.. and gave me a seatbelt ticket. somewhere around 5200ish rpm i want to say? J30 LSD. had plenty of room left to go faster. ran 130mph almost entire trip to penn state university from nj, normally 5 hr drive.. but popo caught me half way through. cock suckers, therese nobody on I80.
1st gear 35 2nd gear 67 after 2nd, i watch the road, not the gauges... ![]() |
#30 | |
