Old 08-21-2002, 12:50 PM   #1
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
So I got the car back from the alignment shop.  It drives straight.  Yay.  I also was having them put new inner and outer tie rod ends on, in hopes of curing the retarded clunk I have in the front suspension.  Well, long story short...no change.  Still freaking clunks!
Here's what I've replaced (and the clunking was there BEFORE I replaced any of these parts...it's been there for well over a year):
Whiteline TC bushings
Whiteline LCA bushings
Whiteline sway bars with poly bushings
Whiteline springs
Koni yellow shocks
Moog ball joints
Moog outer tie rod ends
Moog inner tie rod ends
Swapped strut bearings with a 93 that has no clunk...the 93 has no clunk with my bearings either
Only parts left to replace:
Steering rack bushings (didn't know they existed until last week)
Steering rack
At least I have it narrowed down...but the damn rack is expensive!
So yeah, my day sucks.  Oh, and they said the rear "toe adjuster" was "frozen".  I don't even know what that part is.  Does it freeze?  Can I fix it?  Right now the toe is OK....0.1" toe-in.
Any comments would be appreciated.  Or if you have a rack you want to sell me for cheap, and you know it's GOOD, I'm all ears.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 08-21-2002, 02:35 PM   #2
bbp
bbp's Avatar
bbp is an unknown quantity at this point
I may have a line on a steering rack.  But before you do that, explain, in colorful detail, this "clunk".
Do you have coilovers?
bbp is offline   Reply With Quote
Old 08-21-2002, 03:12 PM   #3
Fuzzy Ewok
Fuzzy Ewok is an unknown quantity at this point
Yeah, explain the clunk and conditions in a bit more detail when you get a chance...
Also, if you haven't done this already, go check every single bolt you can get at up there.  A family member had something that could only described as a "clunk" and it ended up just being a stupid loose bolt (I don't know where it was, though...they finally found it).  But you could actually feel it through the floor, as well as hear it.  But it took us and the shop months to figure it out.
Fuzzy Ewok is offline   Reply With Quote
Old 08-22-2002, 05:01 AM   #4
FORCFED
FORCFED is an unknown quantity at this point
Try checking to see if your springs sit in the purch the right way. My 240 was making a clunk noise when i turned the steering wheel and it was just the spring sitting in the purch the wrong way. make sure to check both top and bottom.
FORCFED is offline   Reply With Quote
Old 08-22-2002, 05:08 AM   #5
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
i had a clunking noise too when i turned the steering wheel...but its fixed now cuz i just took the rubbery plastic thingies that wrapped around the top and bottom parts of my stock springs and walla! no more clunking... <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''> could be wrong though but try it....
s13silady is offline   Reply With Quote
Old 08-22-2002, 05:11 AM   #6
s13silady
s13silady's Avatar
oops haha... i forget to say to put those plastic rubbery thingies on the new springs... hehe... <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''>
Old 08-22-2002, 09:11 AM   #7
GamblerZ
GamblerZ's Avatar
GamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enough
Send a message via ICQ to GamblerZ Send a message via AIM to GamblerZ Send a message via MSN to GamblerZ Send a message via Yahoo to GamblerZ
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''> "...those plastic rubbery thingies on the new springs..."
That certainly gave me a chuckle. &nbsp;I have to assume you must be referring to Whiteline's spiral coil wrap that quiets noisy, clunky springs? &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
Have a good day.
Visit WTI - WestTexasImports.net
GamblerZ is offline   Reply With Quote
Old 08-22-2002, 08:02 PM   #8
maddindian
maddindian is an unknown quantity at this point
Send a message via ICQ to maddindian
I have a 'clunk' or a 'click' when I turn the steering wheel at low speeds (backing out of a parking space)...is this the same noise that you are referring to?
However I have the stock sports suspension (CDN car..so our LE is USDM SE), so I don't think the springs can be put on the wrong way. However the rubber covering over the springs/struts is torn..but I doubt that could be the problem.
-&gt; '99 Maxima GLE &lt;fully loaded&gt;
-&gt; '95 240SX LE 5-spd &lt;fully loaded&gt;
maddindian is offline   Reply With Quote
Old 08-23-2002, 05:28 PM   #9
rampid360
rampid360 is an unknown quantity at this point
Send a message via ICQ to rampid360
Im sure in the course of replacing about every bushing on your car you would have noticed this one if it was the case. &nbsp;My car made a bit of a clunk every once in awhile....turned out to be a snapped bolt on the half-bracket that holds the sway bar in place. The bar was clunking around because it wasn't held securly. &nbsp;(I just puled the control asbly and welded a new bolt on) &nbsp; &nbsp;I doubt it's that, but worth checking in case.
For every winner there are dozens of losers. &nbsp;Odds are you're one of them.
rampid360 is offline   Reply With Quote
Old 08-26-2002, 09:57 AM   #10
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
Like he said all those parts have been replaced and most of the suspension parts were installed at the same time as mine, so they were installed in the same exact way and mine don't clunk. &nbsp;In fact I have his entire stut assembly on my car (springs and struts for 2 weeks even with no clunks).
Plenty of detail is in other posts he started but basically its a loud knock at low speed turns and over big bumps.
If anything is loose it was loose before and after replacing every part he listed. &nbsp;Can anyone thing of a part that could be loose that wouldn't require having a bolt loosened to replace all those psrts?
Steve
93 240sx FB currently very clean and for sale
240 2NR is offline   Reply With Quote
Old 08-26-2002, 10:14 AM   #11
tnord
tnord's Avatar
tnord is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (s13silady @ Aug. 22 2002,06:08)</td></tr><tr><td id="QUOTE">i had a clunking noise too when i turned the steering wheel...but its fixed now cuz i just took the rubbery plastic thingies that wrapped around the top and bottom parts of my stock springs and walla! no more clunking... <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''> could be wrong though but try it....</td></tr></table><span id='postcolor'>
i had the same problem, as well as the same solution, but he doesn't believe that is the issue.
tnord is offline   Reply With Quote
Old 08-26-2002, 10:21 AM   #12
240 2NR
240 2NR's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (tnord @ Aug. 26 2002,11:14)</td></tr><tr><td id="QUOTE"><!--QuoteBegin--s13silady+Aug. 22 2002,06<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (s13silady @ Aug. 22 2002,06<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>8)</td></tr><tr><td id="QUOTE">i had a clunking noise too when i turned the steering wheel...but its fixed now cuz i just took the rubbery plastic thingies that wrapped around the top and bottom parts of my stock springs and walla! no more clunking... <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''> could be wrong though but try it....</td></tr></table><span id='postcolor'>
i had the same problem, as well as the same solution, but he doesn't believe that is the issue.</td></tr></table><span id='postcolor'>
That's an interesting solution. &nbsp;I still have them top and bottom on mine all around (i think) with no clunks, but I'm trying to remeber if his got top and bottom or just one side. &nbsp;I know somewhere a few got ommitted.
Steve
Old 06-17-2003, 05:27 PM   #13
Flybert
I have this same problem. What could this be?
Old 06-17-2003, 05:44 PM   #14
Bill Roberts
Bill Roberts is an unknown quantity at this point
Have you thought about it being the brake pads? Mine do that.
Damn, look at the date...My Bad...but I did not bring the thread back up.....
Flybert, some of the Oldbees don't like the idea of bringing up old topics...prepare for flames...I will don my flame resistant suit...
Bill Roberts is offline   Reply With Quote
Old 06-17-2003, 06:02 PM   #15
hookedup240
hookedup240's Avatar
hookedup240 is an unknown quantity at this point
Send a message via AIM to hookedup240
That is your bushings, they are shot.
PLEASE DON'T REVIVE OLD THREADS, SEARCH OR MAKE A NEW ONE.
hookedup240 is offline   Reply With Quote
Old 06-17-2003, 06:13 PM   #16
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
i hate it too when people bring back the zombie threads, but come on, sometimes you get what you deserve...
all this **** about "use the search button" crap...well, when people do, this pops up sometimes...
also, whats so dam bad about bringing up old threads anyway? are you amazed that people are just doing what you instructed them to do?
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline   Reply With Quote
Old 06-17-2003, 06:19 PM   #17
hookedup240
Hey honestly i don't care if someone revives an old thread. But i was just preparing him for what the mods were gonna say. Or an explanation for it maybe being locked.
Old 06-17-2003, 06:50 PM   #18
crioten
"buddy jesus"
crioten's Avatar
yeah, i know what ya mean, but im tired of hearing people being hippicrates(sp?)
search...wtf did ya do that for...search...wtf did ya do that for...
i dunno, i get mad sometimes...
